01-21-2019, 06:36 PM | #1 |
Options for replacement drums
Wanting to know what my options are for finding a good set of 11" drums for the front end of my '68 C10. The ones I have are waaaay over diameter (up to 11.25). What's my best bet?
1. Buy run-of-the-mill ones at the local auto parts store for $30-40. 2. Post a WTB ad on this site's parts board for some originals that are still in spec. 3. Other options?
Ben '68 Chevy C10 Custom LWB 327/TH400 2nd owner '16 GMC Sierra 1500 SLE Dblcab 4wd 5.3 |
01-21-2019, 07:21 PM | #2 |
Re: Options for replacement drums
I just finished doing a full brake job on my '71.. All new rotors, drums, shoes, pads, wheel cylinders and calipers, along with a power brake booster/master cylinder.. Except for the booster/master cylinder, I used Brake Best Select brand from O'Reilly's.. Good fit, good performance..
Drums and rotors have a way of becoming out of shape during shipping.. What ever brand or source you go with, lightly re-face the friction surfaces before installing rotors and drums.. |
01-21-2019, 09:58 PM | #3 |
Who Changed This?
It is critical that you mount the front drums on the hubs and have them turned before you leave the store. Buy new. I can't imagine that you would save any money buying a used drum, even if it was in spec, and had to pay for shipping.
01-21-2019, 10:10 PM | #4 |
Why do you need to have brand new drums turned? For that matter, how do you attach them to the hub after you cut the factory rivets out?
01-22-2019, 07:14 AM | #5 |
Try Rock auto just bought 2 for the rear of mine reasonable.
01-24-2019, 09:20 AM | #6 |
Ok, so the replacement parts I can get at RockAuto, etc. are good quality? I’ve read some posts that make it sound like they’re not a good option. Are there multiple sources for these drums, or are they all made by one supplier?
01-24-2019, 11:02 PM | #7 |
Who Changed This?
They should be mounted on the lathe together to make sure that there is no run-out due to manufacturing tolerances. After the rivets are drilled out, care must be taken to put the drum on the hub if it is removed, for the same reason.
