Old 01-24-2019, 11:22 AM   #1
panhead59
Electric fan kits
Does anyone sell elec. Fan kits ? Looking for a kit with fans,shroud, controllers. Basically Everything needed for elec. Fan. Conversion. Also, what amp alternator is needed for dual fans that draw 47 amps ? Non ac car/truck. Tks
"You are not forgotten" USMC 75-79 (Aviation Ordnance Tech- F-4 Phantom)
1959 H-D Panhead. Owned since 1978. Currently with son in Lawton, OK.
1968 Chevy Custom SWB pick up. Fleetside. Lowered 4/6. Totally refurbished. 1966 Pontiac GTO. 4 speed. Saved original 389. Now has slightly built 455 engine. 355 rear gears. Very fun to drive !
panhead59 is offline   Reply With Quote
Old 01-24-2019, 02:07 PM   #2
hayhauler71
hayhauler71's Avatar
Re: Electric fan kits
https://www.flex-a-lite.com/electric...ontroller.html
This is the one i use and never had a problem. States 28 amps spike but I tested 12 amps running. Just remember the higher the rated amps the cheeper the motors.
Fuzzy
hayhauler71 is offline   Reply With Quote
Old 01-24-2019, 02:46 PM   #3
my67c20
This is the one I got from Entropy with the controller. All I had to do was connect battery power, switched battery power, ground and change the temperature switch. The picture is before I cleaned up some wiring. cost about 1K. Not the cheapest solution, but not gonna trust my motor to a cobbled together set-up.
http://www.entropyrad.com/1967-1972-...-radiator.html
my67c20 is offline   Reply With Quote
