01-26-2019, 09:21 PM | #1 |
Door over close problem
so i took of my weather stripping and was gonna put on new new kit. but i discovered that the idiot who owned the truck before me replaced the rockers with ones that don't have the pinch weld along the rocker for my weather stripping. So now comes the bigger problem, I was upset and quit for the day to figure what what to do so I shut the doors and locked up come back out days later, driver door opens just fine passenger door? nope! will not budge i called my good friend mike he told me oh yeah he had it happen to him before the door is over closed now. With no weather stripping in it he said he had to pry his open with a pry bar! if this is the only way then so be it but I am just asking is their any other way to get it open again? without prying on it ? I really don't want pry it and most likely bend the metal of the door or the rocker or both ? I am asking is their another way to do this where i wont damage my truck? Thanks guys my buddy mike knows a bunch about these trucks so i trust him that is not a issue i just really want to get it open without hurting it ya know
01-26-2019, 09:34 PM | #2 |
Re: Door over close problem
you might try some plastic pry tools, i bought a cheap 10 piece set to take off trim on my toyota , i have put them to good use on my suburban. really helped put weatherstrip on my side windows and a few other general prying against metal jobs.
1965 Suburban, 2 wd.,292, 4-speed. proudly owned and operated since Valentines day 1969. |
01-26-2019, 09:36 PM | #3 |
Problem is I don't think that plastic ones will be strong enough to pry open the door I have pulled with all my force and all my weight I weigh 400 lb to try and open this door and it won't open it won't budge so Something tells me that the door would just laugh at a piece of plastic trying to pry it open
01-26-2019, 09:44 PM | #4 |
i heard a good boot from the inside will open a stuck door. good luck.
01-26-2019, 09:45 PM | #5 |
01-26-2019, 10:14 PM | #6 |
well it involves a little work...one option is to remove the cowl extention...loosen the fender at the bottom to access the hinges to wiggle the front of door to try to separate the latch....or maybe access latch by removing door panel...Good luck
01-27-2019, 10:35 AM | #7 |
It's Better With Nitro
Before you start using pry bars and damaging the sheetmetal, try removing the front fender and cowl corner to access the hinges. Loosen the bolts that hold the hinge plate to the cab and door. Hopefully, by allowing the hinge mounts to move will take enough tension off of the door to allow it to open.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
01-27-2019, 01:37 PM | #8 |
I started a post but erased it got to thinking do you have the latch installed or do you think it’s stuck on the rocker
01-27-2019, 06:42 PM | #9 |
Moderator
Reminds me of Galaxy Quest.
01-28-2019, 08:12 PM | #11 |
hey guys thank you all of you for all your suggestions and valuable help!
I am happy to say that i got open before having to dismantle the cowl corner and the front fender. it is funny how bad it was jammed shut that nothing done not having a guy lay down put pressure with his feet and me hanging my full 400lbs on the handle just shook the truck all over lol nothing would make that SOB give. LOL in the end the guy inside rolled down my window and said hand my the pri bar he stuck it between the door and the door jam right where the latch would be and literately applied the amount of pressure it takes to crack your knuckle and it popped right open LOL with just me pushing the button no yanking no extra damage done and door it open soon i will be putting on my new weather stripping on and wont ever be a issue again lol but much thanks to all of you |
01-28-2019, 08:17 PM | #12 |
call me superstitious but after posting this i saw the log under my name of how many posts and it was 666 no thanks ! so that is the reason for this post now
01-28-2019, 11:30 PM | #13 |
1961 GMC half ton, short step, Canadian model. Just starting work on it. |
01-29-2019, 08:48 AM | #14 |
LMAO. Yeah that’s what I did when mine got stuck But I didn’t have to worry about Paint it still look like the aviator
02-01-2019, 01:02 AM | #15 | |
1961 crewcab
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
02-01-2019, 01:06 AM | #16 |
02-01-2019, 09:00 AM | #17 |
The little rubber bumpers would also keep this from happening
01-28-2019, 11:39 PM | #18 |
I dunno, but I think if you had rolled down the window, and applied upward pressure at the rear corner window opening, it would have lifted the door off the part it was binding against. The weatherstripping will force the door up a bit and mask a misalignment
