02-01-2019, 10:24 PM | #1 |
Motor mount frame stand perches
Still bolted to the frame. Off of a 1970 C30 with a 250. From the research I’ve gathered and other members help the driver side is a direct interchange with the 292. Passenger will not work with 292
Will work for small block, but when put in the forward holes position the 1 lower hole on each side must be drilled to be able to bolt down(obviously not factory correct, but function for a sbc) $45 shipped in the upper 48
70 C10 highschool truck now C20 cummins powered 72 Crew Denali, Bigger, Stronger, Faster, well you get the point..... the ole 65 continental Syclone killer AWD T56 LS Paypal please pay as Goods&Services Madkidd00000007@yahoo.com Last edited by Madkidd007; 03-03-2019 at 03:57 PM. |
02-22-2019, 02:45 PM | #2 |
Re: 6 cylinder motor mount frame stands
Take any reasonable offer, can’t stand the thought of throwing good metal away
70 C10 highschool truck now C20 cummins powered 72 Crew Denali, Bigger, Stronger, Faster, well you get the point..... the ole 65 continental Syclone killer AWD T56 LS Paypal please pay as Goods&Services Madkidd00000007@yahoo.com |
02-22-2019, 03:16 PM | #3 |
Those will work with the V8 engines and the 230 and 250. The passenger side on a 292 is different. The V8 and small six will not work with a 292
02-22-2019, 03:20 PM | #4 |
Thank you for the info, I’ve learned if I don’t know I will state I don’t know so that may be helpful to someone in need of these
03-03-2019, 03:57 PM | #5 |
Thread updated after doing more research
03-15-2019, 10:53 AM | #6 |
Will separate if you only need one or take offer on the pair. Trying to clean up and going for a scrap metal run today or tomorrow
04-21-2019, 09:38 AM | #7 |
Bump, these are still bolted up
10-31-2019, 03:29 PM | #8 |
Ttt
11-14-2019, 12:40 PM | #9 |
I'm interested, if you'll included the 45 degree pieces that bolt the 6 cylinder motor to motor mounts.
11-14-2019, 04:51 PM | #10 |
If you’re referring to something that is not in the first 2 pictures then I don’t have it. The last picture is only a reference from before the motor was pulled when I bought the chassis.
11-14-2019, 06:30 PM | #11 |
I can't see them in your 1st two pictures, so you likely just have the perches that mount to the frame. I'm looking for the the piece that is bolted to the engine cradle, in this picture.
11-27-2019, 12:07 PM | #12 |
$33 shipped
