Old 02-02-2019, 09:37 PM   #1
Blk63vette
Brake job 101
Hello
Took off the front tire and this is what I found. I guess torching front hub off is easier than removing the rivets that hold brake drum in place.
Blk63vette is offline   Reply With Quote
Old 02-03-2019, 11:12 AM   #2
Chevy Fleetside
Chevy Fleetside's Avatar
Re: Brake job 101
It took me a while to figure out the picture. Looked like the hub was rusted but after looking, it seems that is part of the drum that is rusted onto the hub. If you remove the hub you should be able to press the studs out and get that apart or the part is just junk and might need to find another hub which would probably be a lot easier.
You could also remove the hub and soak it in penetrating oil for a few days. More then likely it can't be save but you will never know unless you try.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 02-03-2019, 12:54 PM   #3
Blk63vette
Re: Brake job 101
Hello
I think the hub can be used. It had sat in a Texas barn since 1987. I think when the guy I bought it from moved the truck this side was locked up so it only natural to torch the drum off to get the car rolling again to get it In on the trailer. ��
Old 02-03-2019, 02:19 PM   #4
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Re: Brake job 101
Wow , I'd go over the whole truck now to see what else he did?
Old 02-03-2019, 04:12 PM   #5
Blk63vette
Re: Brake job 101
This truck will need everything. This gonna take a while to get it road worthy again. This has been sitting in a field in Texas since 1987. Everything is a mess.
Old 02-03-2019, 04:37 PM   #6
Blk63vette
Re: Brake job 101
This truck will need everything. This gonna take a while to get it road worthy again. This has been sitting in a field in Texas since 1987. Everything is a mess. Any help would greatly aporecitated. This took my 14 + years to do a 1963 Corvette
Old 02-03-2019, 04:54 PM   #7
Blk63vette
Re: Brake job 101
Here is my 1963 Corvette
Old 02-03-2019, 05:07 PM   #8
Blk63vette
Re: Brake job 101
Attachment 1871978
Old 02-03-2019, 02:20 PM   #9
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Re: Brake job 101
Have you considered just swapping it all out for 73-87 power disc brakes?
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 02-03-2019, 11:10 PM   #10
straight6chevyguy
straight6chevyguy's Avatar
Re: Brake job 101
One sharp vette!
I like the truck to by the way!
1965 chevy c20 292 4speed http://67-72chevytrucks.com/vboard/s...d.php?t=777601
1976 chevy c10 250 4speed http://www.67-72chevytrucks.com/vboa...d.php?t=787037
1978 chevy c20 350 4speed
1998 chevy c1500 4.3L 5speed
2002 Chevy s10 4.3L auto 4x4
Plus a Mercury & some Fords... To many projects!
straight6chevyguy is offline   Reply With Quote
Old 02-07-2019, 08:31 PM   #11
Blk63vette
Re: Brake job 101
Originally Posted by straight6chevyguy View Post
One sharp vette!
Thank you she got a long way To go
Old 02-04-2019, 07:53 AM   #12
aerotruk63
aerotruk63's Avatar
Re: Brake job 101
Lacking any knowledge on 64-66 why is the A/C compressor and alternator switched sides?
Old 02-04-2019, 07:29 PM   #13
jdl71
jdl71's Avatar
Re: Brake job 101
Possibly later model accessories and or engine. I have a '74 350 in my 66, alternator is on the right. Same with my '85, alt on rt, a/c on left.
Psalm 23
64 C10
66 K20
jdl71 is offline   Reply With Quote
Old 02-04-2019, 10:19 PM   #14
Blk63vette
Re: Brake job 101
Hello
Yes they are! Apparently the previous owner decided that he was going to use newer parts to replace worn out ones? So, he has cobbled up the wiring harness and none of it makes any sense. He also put on a long neck water pump and new style pulleys that do not line up. The owner died then it sat out on a farm in Texas for over 30 years
Good news I bought correct pulleys and brackets and compressor to put them no back original. Any pictures of original ac set up greatly appreciated
Old 02-05-2019, 07:53 AM   #15
aerotruk63
aerotruk63's Avatar
Re: Brake job 101
Originally Posted by Blk63vette View Post
Hello
You can buy a year specific Accessories Installation Manual in original / reprint which will give you the Dealer Installed A/C instructions on Ebay. Good investment for your build.
Old 02-07-2019, 08:32 PM   #16
Blk63vette
Re: Brake job 101
I’m going need something to figure this out for sure. I never seen a truck this vintage with ac before
Old 02-05-2019, 12:31 AM   #17
Captainfab
60-66 Nut
Re: Brake job 101
That accessory drive configuration is '69+ car and '73+ truck. Typically when an engine is swapped, 90% of the people leave that style on the engine rather than change to the factory correct style.
Old 02-05-2019, 07:39 AM   #18
PGSigns
PGSigns's Avatar
Re: Brake job 101
Nice truck. Yup it will take a while but always worth it when you get your first ride down the road.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 02-07-2019, 08:33 PM   #19
Blk63vette
Re: Brake job 101
Jimmy
Thanks a Jimmy
I got no to need your service on my dash cluster for sure
Old 02-08-2019, 08:17 PM   #20
DPowers
One foot in front of the other
DPowers's Avatar
Re: Brake job 101
At least they left the original shroud and radiator hose when they put it back together.
DPowers is offline   Reply With Quote
Old 02-09-2019, 01:31 PM   #21
Jeffh
Re: Brake job 101
Here is my little remedy for frozen brake drums. Tried and tested many times on 55-57 cars I have drug out of fields. It will turn the drum inside out and twist the shoes into pretzels but it has never been known to fail and gets them rolled up on the trailer.
Jeffh is offline   Reply With Quote
