02-09-2019, 10:17 AM | #1 |
Loud thump
When I was driving my truck back from college this past weekend on interstate my truck just died then I heard what sounded like a rubber mallet hitting the inside of my gas tank. Headlights didn't flicker at all or voltage didn't drop just died then the large thump came from the gas tank. Truck started right up after I came to a stop like nothing had happened. Any thoughts to what may have caused this?
02-09-2019, 10:21 AM | #2 |
BlahBlahBlah
Re: Loud thump
02-09-2019, 10:51 AM | #3 |
Re: Loud thump
Just guessing here, but possibly your tank vent is plugged (fully or partially) and the fuel pump was pulling a vacuum in the tank and when the engine died (from lack of fuel) the vacuum was released and the tank popped back to normal. Or the tank popped out of shape from the vacuum before the engine died.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
02-09-2019, 01:15 PM | #4 |
Re: Loud thump
what HO455 said
02-09-2019, 06:10 PM | #5 |
Re: Loud thump
Its a 1969 GMC where can I find the vent on the tank?
02-09-2019, 07:06 PM | #6 |
Re: Loud thump
Did you by chance happen to replace your gas cap recently? I believe a 69 gmc should be using a vented cap. If so, maybe you got a cap for a later model with a vented tank. (Cap not vented). Or maybe the vent on the cap is plugged. If air is not allowed into the tank as gas is consumed the tank will suck in a bit. Your truck will run until the fuel pump can no longer overcome the vacuum in the tank. The thump you heard was probably the tank either collapsing a bit or returning back to shape. If it happens again, loosen the gas cap and see if you hear air sucking, your truck should then run.
1972 GMC K2500 Super Custom Matt |
02-09-2019, 08:20 PM | #7 |
Re: Loud thump
Your fuel pump pulled as much gas as it could out of the tank, without any air going into the tank to replace the gas. It reached the point of not being able to pull any more gas to deliver to the carburetor and then died. The fuel tank then popped back into shape. In 1969 there was no complex ventilation such as charcoal canisters under the hood connecting to a separate air line that goes to the tank. You probably just have the gas line coming from the tank and that is all. So that means you need a gas cap that will let a little bit of air in. The vented caps let air in, and don't let fumes out unless the pressure exceeds a certain amount such as from heat expansion when the parked truck is sitting in the sun.
02-19-2019, 11:31 AM | #8 | |
Re: Loud thump
72 C10 lwb fleetside -stock 350/350 combo |
02-18-2019, 11:16 PM | #9 |
Re: Loud thump
Tank vent plugged same
02-19-2019, 11:27 AM | #10 |
Re: Loud thump
Sounds like you burped the fuel tank to me
