02-09-2019, 11:11 PM | #1 |
Proportioning valve placement
Hey I'm just checking to see where everybody is placing their proportioning valve on a C10 pickup with disc front drum back brakes I'm looking for some ideas any input would be much appreciated
02-10-2019, 01:49 AM | #2 |
Re: Proportioning valve placement
The original mounting should be a bracket attached to the booster, right next to the master cylinder.
My truck is almost 100% original, but it's not the best pic because I took this a few days ago, focused on the valve itself, not the mounting. But those are all original brake lines.
I know a little about cars, but if you have a question about electricity or sport quads, I'm your man!!! |
02-10-2019, 02:40 AM | #3 |
I’ve considered mounting mine to the frame just below the master.
Really, it can go just about anywhere
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
02-10-2019, 10:37 AM | #4 |
Moderator
As an FYI...
If the original truck was a drum/drum system, the original valve block near the master cylinder is not a proportioning valve...its a simple brake circuit valve to alert of a hydraulic circuit leak. Most proportioning valves are located close to the master, mainly to keep the pipe layout simpler. Most square body trucks have their prop valves located on the front chassis cross member...making it difficult to access for us old guys! Have fun !
Family and country before all others... 2006 Chevy Silverado (Daily Driver) 2012 Chevy Equinox |
02-10-2019, 10:56 AM | #5 |
Hey really appreciate the feedback to clarify things I have a 67 C10 I changed the front disc drum in the back will wear of metering block the proportioning valve difference.
Was just wondering if placing the proportioning valve in a different spot would make it easier to Plum the front brakes since each caliper gets a line to itself whereas the back gets one line to the T & T's off. Just trying to see if anybody had any need ideas out there if placement for ease of rePlumbing the lines. Once again thanks for the feedback guys appreciate it |
02-10-2019, 11:04 AM | #6 | |
Moderator
02-12-2019, 03:42 PM | #7 |
Agree
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs 67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive 58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white 69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive |
02-10-2019, 11:03 AM | #8 |
Ha...yah hear ya Aussiein NC. It was a lot easier crawling around these things when I was 18.
How long have you been playing with electricity wilkin250r? Ive been from '89. |
02-10-2019, 01:15 PM | #9 |
Use the '73-up brake lines and under the radiator mounting location for the Combination Valve. It's a bolt-up conversion with salvaged hard lines and direct replacement square body flex lines.
http://67-72chevytrucks.com/vboard/s...es#post6686402
'67 GMC 2500, 292, 4spd, AC |
02-10-2019, 04:41 PM | #10 |
Just did this on the last truck , down on the frame. Didn't make anything easier ,I just didn't need to see it.
02-12-2019, 12:20 PM | #11 |
Wow love how cleaned up that engine compartment looks that's an interesting spot for the proportioning valve does look better nice work
02-12-2019, 04:32 PM | #12 |
stock look on mine
Fuzzy |
02-12-2019, 08:32 PM | #13 |
Sub’d
02-13-2019, 03:20 PM | #14 |
Went with the stock look and set up on mine. Wasn't real sure if the original proportioning valve was good, took awhile to bleed system but brakes work well now. I didn't have the tool that service manual said was necessary to hold prop valve open during bleeding process, but they bled ok, nice firm brake pedal.
1972 Blazer Highlander 1971 GMC K1500 SWB (sold) 2004 Corvette Z06 CE |
