Old 02-11-2019, 07:15 PM   #1
kipps
Is there any way to get wires through the A-pillar?
I'm doing a custom rewire, and want to avoid running wires across the floor, but the dome light is still needing power and ground.
My fall-back method will be to run the wires across the tranny hump, sleeved through a piece of metal oil line for protection.
I'd like to get those wires up the inside of the A-pillar, but I'm assuming that's impossible. Can anyone give me a definite yes or no?
kipps is offline   Reply With Quote
Old 02-11-2019, 07:19 PM   #2
sweetk30
sweetk30's Avatar
Re: Is there any way to get wires through the A-pillar?
long fairly stiff length of wire like tig welding rod .
there is a spot under the dash were its open in the a-pillar .
if you have 5-lights on the roof this is were the wire goes . so yes it can be done . also try puling the sun visor and maybe going down threw that hole and let gravity help . then its just back across the top is all .
i just had my silverado apart and inside and the wires for the dome/speaker/cargo light all went along the carpet to door sill area and then up the b-pillar .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 02-11-2019, 07:40 PM   #3
kipps
Thanks for the info. I'll look into it. Fencing wire should work for threading through.
I don't plan to install carpet and door sills at this point. Maybe at some point in the future, but for now, bare metal is fine.
Old 02-11-2019, 08:49 PM   #4
mongocanfly
mongocanfly's Avatar
I rethreaded the wire for the clearance lights in mine with string and a vacuum cleaner...
tied a heavy knot on the end of the string
dropped the string in from the top
stuck vacuum nozzle up to hole under dash
sucked it right on thru
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
