02-11-2019, 11:03 PM | #1 |
If I had more brains...And more money. (New Whole Cabs)
02-11-2019, 11:28 PM | #2 |
Re: If I had more brains...And more money. (New Whole Cabs)
Nice, and I would like to have a five window. But that cab costs more than I paid for my truck. Interesting that the market is large enough to make this viable.
53 Chevy 3100, SBC 355, 700R4, S10 frame, Ford 8.8 rear with 4.11 gears, front disc & rear drum brakes |
02-12-2019, 12:48 AM | #3 |
yep...its a lot of money...but if your cab is like most needing extensive rust repair...and you counted your time and materials...in the long run itd be cheaper....but if you have a good cab with minimal rust then itd be a nogo..
if you've ever worked with one that didn't need a bunch of repairing then it kinda spoils you.. there was a thread here the other day about a different company selling the cabs...probably made by the same people
02-12-2019, 01:43 AM | #4 |
But it's still a reproduction, "similar to original, can be used if nothing else is available." But at the same time, these cabs and doors were MILES from perfect from the factory, I have a feeling those doors fit better than originals.
I have to wonder how good they are. This is also coming from a guy who will be ordering his new bed complete with tail gate from LMC this week. LOL Brian
1948 Chevy pickup Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats! Bought with paper route money in 1973 when I was 15. "Fan of most anything that moves human beings" |
02-12-2019, 04:39 PM | #5 | |
1951 Chevy Panel Truck |
02-12-2019, 04:47 PM | #6 |
Brings up Theseus' Paradox: if a 1953 Chevrolet truck has had every single component replaced, is it still a 1953 Chevrolet truck?
https://en.wikipedia.org/wiki/Ship_of_Theseus And how will the VIN plate paranoiacs handle removing a VIN plate from the old cab and affixing it to the new? I can just hear them now: "Federal offense - you're going to prison!" |
02-12-2019, 02:54 AM | #7 |
what about mar-k for your bed Brian?
02-12-2019, 02:57 AM | #8 |
mar-k?
Brian
02-12-2019, 06:27 AM | #9 |
https://www.mar-k.com/
top quality products...I bought all my bed components from them..sadly they don't do fenders...but the rest is top notch much better than anything ive got from lmc
02-12-2019, 07:15 AM | #10 | |
02-12-2019, 11:39 AM | #11 | |
Thanks again. Brian
02-12-2019, 08:36 AM | #12 |
I think I'm with Brian in regards to panel fit. I can't tell you how many hours are sunk into making the body line at the top of my TF window opening match the body line on the cab. And the cab was assembled wrong... the RH doors (I tried two originals) couldn't have left the factory with proper fit. The RH door pillar was welded in crooked so the bottom of the cab was below flush when the door was adjusted properly. The hinge pillar ended up getting work as well. I had to build hinge pockets since the available ones just didn't fit right. The floors needed repairs in all the typical areas and the stamped support ridges did not line up with the factory stamping. The replacement cab corners needed to be hand formed to actually match the shape of the body lines in the rocker and at the back of the cab, and I had to remove a section in the bottom of the curve because they let the excess steel fold into an accordion rather than designing the mold to form it properly. There's so much time invested making the old cabs look nice that it's hard to understand until you go through it.
The problem is I just don't know if I could part with the money for the new cab up front. $11,000 invested in weekends and evenings over a year is a different animal than $11,000 divided up and taken out of the weekly budget. Last edited by 1project2many; 02-12-2019 at 08:54 AM. |
02-12-2019, 10:55 AM | #13 |
Its awesome you can basically buy a new truck but I don't think I'll ever have that much spare cash lol Has anyone added it up from a places like LMC what it would cost to get a 100% new truck?
What is the average cost to have a rusted cab repaired from a shop? All usual stuff like corners, floor... sandblasted, primered... vs buying this new cab?
1950 Build |
02-12-2019, 12:05 PM | #14 |
here is the write up from the hotrod network for premier street rods new cab assembly. they use jigs as they go for a product that fits when complete. I have never seen a finished new cab from anybody so don't know how any of them fit but these guys seems to at least try to get a good product. I wonder if all the parts were added up how much the cab costs to build without the labour for the guys building it or the special tools required or the shop time, jig research and build etc etc.
like said earlier in the post, the old trucks were not that great for fitment anyway and some guys spend a lot of time getting things right with an original cab and doors. there is a thread on here about a $188k truck built at a hotrod shop and then auctioned off a bit later by the owner. there is a prime example of where a new cab, fenders, box etc could have saved a lot of time and money. if you fix it yourself and don't count the time it is a bit different but still can be costly. some guys will say they did the rebuild but then when asked they simply took it apart and sent the modules to get fixed. the rust repair was done at this shop, the body was done at that shop, the engine was done here, the trans came from there, the frame these guys, the wiring from those guys, etc. add those numbers and compare. a new cab and a new custom frame may be cheap in comparison to the unknown final number of building a truck that way. from experience, if I had bought the new cab when I had started I would be driving my truck right now. the cab was pretty bad but you are just happy to have found a project truck and be endorsed by the "accountant" finally. it was cheap but needed work. holy cow, that's an understatement for most of us. once it is dissassembled and you add up all the parts, welding and sheet metal supplies. power, extra tools you didn't have, sandblasting, etc etc and time spent, it would be cheaper to buy new. especially if you have a job where you need to NOT work the second job so you can work on your project. that is time lost at the second job which could be worked instead to pay for the cab. see where I'm going here? you get NEW sheet metal, never welded on or patched up with rust on the back side etc. you don't have some one else's previous repair lurking behind filler or patch panels. the truck is done faster and the accountant will be happier since you will have more quality time to spend doing together things (I know, right?) anyway, just a thought for some of the newbies, you gotta start somewhere and will need a registration from some original vehicle likely but you can sure open a can of worms with some projects. sometimes, if you can't afford the new cab or whatever, it is better to pay a bunch more for a known good solid unit with some build history than get something almost free and then spend more money to fix the crusty stuff. in the end you get something fixed. ok, end of rant. sorry. https://www.hotrod.com/articles/prem...hevrolet-cabs/ |
02-12-2019, 12:12 PM | #15 |
imagine what the bill on the $188k fantomworks truck would have been if they would have ordered this cab, in the episode the cab seemed to be the biggest problem.
I have spent a hundred hours fixing rust, it can sure get old.
02-12-2019, 12:30 PM | #16 |
Yeah, the cab with all it's nooks and crannies is a rust party ground!
Brian
02-12-2019, 12:41 PM | #17 |
Premier street rods has been assembling and selling cabs for years. I have to agree with Joedoh about that Fantom works truck. I'm not sure what they paid for the roached out replacement cab but it no doubt wasn't cheap plus probably 30K worth of their shop hours to make a cab out of it.
The 10399.95 for the 52/53 cab with recessed firewall equals 104 hours of 100 an hour shop time costs. If you are paying someone else to repair your cab that needs a lot of work the price of the new cab is a lot more realistic than if you are doing all the work in your home garage and buying patch panels a few at a time No it isn't "the original" that some guys are so totally wrapped in and spend thousands of bucks saving the"original" cab that was so roached out to begin with that very little of the original is left. The Cab I am putting together for my 48 will be the third cab that has been on the truck since I bought the truck for 75.00 in 1973. That cab was damaged in a wreck and had other issues. The cab on it now has issues that would call for replacing a lot of it including my 80's idiocy of wanting a sun roof and then filling the hole that was left when I decided I didn't want a sun roof anymore.
02-12-2019, 12:50 PM | #18 |
Looking at Fantom works website faq their shop rate is between 78.00 and 98.00 an hour so figure 80 an hour that 10399.95 equals 130 hours for their body men. That is for guys who don't seem to know the ins and outs of working on AD trucks all that well and spend a lot of extra time on tasks a lot of guys do here in short order.
02-12-2019, 01:31 PM | #19 |
just have to add an additional 1000.- for shipping
wonder if you can get the same cab cheaper elsewhere .... ?
dont want to hear excuses, i want to hear solution(s) |
02-12-2019, 03:04 PM | #20 |
Yes...LFR....here is one for $7995.....https://www.premierstreetrod.com/dep...ruck+Cabs.html
If a person kept up with the hrs and cost of repairing a cab on their own ,and divided costs and hrs up I'd be willing to bet you couldn't pay yourself minimum wage with the time you have invested...and most of us, not being pros means most repairs take us much longer than it should.... now if your paying a shop to fix what most of us deal with then youd be money WAY ahead to buy a new cab...just divide the new cab cost by the hrs invested.... some if us have sentimental attachments to the trucks we have...so we will toil away at our rusted out junk... And even though we do repair all the rust we can on our trucks you'll never get rid of all the rust...
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 02-12-2019 at 03:25 PM. |
02-12-2019, 03:17 PM | #21 |
Martin...on the bed I know the mar-k is higher and shipping costs suck...I've only held in my hand ,pieces of a LMC bed..not the whole thing...but piece for piece the mar-k is much heavier gauge metal and overall quality beats the socks of LMC...so when I bought my bed I went straight to mar-k and sucked it up......I wish mar-k made the rear fenders also but they dont....I bought my new rear fenders some 20odd yrs ago..they're still in the boxes up on the shelf....the fender boxes have tri-plus on them
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 02-12-2019 at 03:28 PM. |
02-12-2019, 05:42 PM | #22 | |
Brian
02-13-2019, 11:20 AM | #23 | |
You could contact some vendors to see if they will be at any swap meets in your area. I try to buy my big items local or at the Portland swap meet, The truck and car shop is there every year. Then you can see the parts and save shipping cost.
1951 Truck, LS1/4L60 1964 Suburban, current project 2014 Silverado daily driver 1953 Westerner "canned ham" trailer, rebuilt 1974 Prowler trailer, rebuilt |
02-13-2019, 03:17 PM | #24 | |
The bed pieces don't go over a $1000 but with all the other stuff I am ordering it does. I really wonder, I would be ticked it they sucked, but anything pretty close I would forget real quick that it's not perfect. But I am still rolling it around in my head, American made, real nice, I am thinking about it. Brian
02-13-2019, 03:50 PM | #25 |
For some reason, watching that video of the cab assembly makes me want one even less. Maybe it's the lack of professionalism, or just a regular dudes in t-shirts building it. I don't know. I'm sure my cab that was built in 49 was just a sloppy, and probably even less safe. I just don't know. Makes me glad I fixed my original cab.
