10 years ago
I was here a lot reading and learning....I tell people I learned to restore my truck from this website. Amazing what you can absorb from here. I learned to weld, paint, and take things apart. I did too much at one time and learned to be patient. There wasn't a lot of youtube videos at the time and I was able to get this truck mostly together and then my situation changed and i had to employ help to finish. For the last 10 years it has be extremely reliable. I live in the city so its hard to find time to drive it. It spends time in the garage and then once a month I get it started and take it out.
A few weeks ago went out to start. I pump the gas a few times, turn the key and it takes 15 seconds or so it fires up. this time was the same except the gas pedal got stuck under the floor mat and the truck revived super high. I turn it off and have not been able to get it started since. I THINK I'm not getting a spark but was getting 12 volts at the ignition coil. I'm not really in the repair mode mind set so its hard to articulate what I've been doing or need to do. I replaced the cap and rotor, ignition coil, and starter switch. Then last night I realized that my wires were wrong going to the distributer cap. I straighten that out but still not starting. Any thoughts or suggestion on what to do next? |
Re: 10 years ago
I simple check to see if you have spark at the plugs is to pull out a spark plug and hold it with an insulated handled pair of channel locks so that the curved tip (or threads) is touching something grounded (like a bare spot on the block or engine/exhaust bolt) and have someone turn the ignition key like they are trying to start it. You should see the spark at the tip jumping to the curved portion of the plug. It's a good idea to unplug the remainder of the plugs so that the truck does not actually start (at the plugs) and check the other plug wires with your removed plug individually. This eliminates any problems with the firing system (asuming that your firing order is now correct and your timing is on), but will not actually check every plug unless you remove them individually and check them too. Chances are the plugs are good unless they are flooding.
He who is without oil shall throw the first rod. Compressions 8.7:1 1972 C10 1976 C10 (parts truck) 1985 K20 Last edited by sick472; 02-13-2019 at 01:53 PM. Reason: typos |
![]() Join Date: Feb 2016
Re: 10 years ago
Unfortunately from the events you describe I think you may have a timing chain issue. I would confirm the timing before going further. When you found the problem with the ignition wires I am assuming that you found them all off and not a couple of them switched. Have you noticed any backfires?
Line the balancer up at TDC on the firing stroke and check that both the intake and exhaust valves are closed. You may have to pull the water pump and timing cover to be sure. If you have the cam card and a degree wheel (or the correct timing tape installed on your balancer) you should also be able to verify the timing chain hasn't jumped without pulling the front of the motor off. Good luck I. Hope I am wrong.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
#4 | |
Re: 10 years ago
He who is without oil shall throw the first rod. Compressions 8.7:1 1972 C10 1976 C10 (parts truck) 1985 K20 |
Re: 10 years ago
ok. I've only got as far as I know I'm NOT getting a spark. According to my inline spark tester. I'm not sure if this evidence for a timing chain problem or means there is other things to look at.
Re: 10 years ago
For the most part the only thing that would cause a no spark problem and be the timing chain related would be if the chain has broken completely. That is easy to check by removing the distributor cap and watch the rotor while bumping the engine over. If it doesn't rotate then it it isn't connected to the crankshaft any more. If it does then you should be good.
No mention if this a point style or a HEI distributor. Either way a quick inspection of the mechanical advance may be a good place to look for broken springs or damaged wires. The over RPM situation may have caused a spring to fail and now part of it is shorting the points to ground or it has broken a wire or a module.
Re: 10 years ago
I'd put a wrench on the crankshaft at rotate it back and forth to see if the distributor moves in time or lags. How many miles on the motor? If you have a plastic-tipped cam gear you might have detonated it with the over-revving.
1981 C-10 Longbed, 250 (4.1) 2bbl Varajet, THM-350C. Some of the Build progress: https://www.youtube.com/channel/UC_W...foLyeDq_WQPNmA 1981 Harley Davidson. Credentialed, semi-retired A.S.E. technician. If you don't like free advice, Ask Someone Else and pay for it. |
Re: 10 years ago
ok,, simple check, pull the cap, turn the engine, the rooter turns, the chains not snapped, no spark? check your electrical (All the wires) might also check the ground strap. save puling apart stuff for later.
'69 long bed \ 334" LB9-700R4 |
![]() Join Date: Mar 2011
Re: 10 years ago
im going to stay tuned ...all real good advice so far
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
Re: 10 years ago
this could be my problem?
Re: 10 years ago
Yep!
'67 GMC 2500, 292, 4spd, AC |
Who Changed This?
![]() Join Date: Jan 2013
Re: 10 years ago
That's got to be the first time I've seen that, and I've installed hundreds of point sets. Crazy.
Re: 10 years ago
That sure enough would open the point gap.
![]() Good job! I too have never seen a contact drop off like that. Seen them welded together, but not this. Must be the super glue they use assemble things now days.
