Is it just me? Headlight adjustment screws!!
Another case of simple stupid has got me stumped.
I'm trying to replace the headlight adjuster screws and the plastic clips that they screw into. I've bought and broken 3 of these clips trying to get them to seat into the square hole in the core support. I thought it was just cheesy Chinese quality so I bought some from LMC with a recent order. Looks identical to the local parts store pieces. The issue is they will not clip into the hole securely. I can't pull them thru far enough that the tabs lock them in place. Is there a secret to this? |
#2 | |
Re: Is it just me? Headlight adjustment screws!!
4x4k30 if trouble was money i would have plenty |
Thanks.
That's what I have been doing but it won't come forward enough for the tabs to snap outward and hold it in place. When I try to carefully pop the tabs out they snap off. |
Hmmm...maybe I'll just tackweld a nut to it and be done with it. Don't know why it has to be plastic anyway? In Arizona we don't have rust, so that's no concern.
Maybe let them soak in hot water first?
I had to replace two of them, but the ones I got at O'reilleys went in fine without it. Maybe you will need to file the plastic a little bit?
1981 C-10 Longbed, 250 (4.1) 2bbl Varajet, THM-350C. Some of the Build progress: https://www.youtube.com/channel/UC_W...foLyeDq_WQPNmA 1981 Harley Davidson. Credentialed, semi-retired A.S.E. technician. If you don't like free advice, Ask Someone Else and pay for it. |
I wouldn't worry too much about getting them clamped in the core. If you install them from the rear, the spring pressure pull through from the headlight shell will keep them in place. You could cut the spring clips off and glue the rest in place if you thought they would move, but I think that step would be overkill.
That’s why I stick with NOS GM.
I have heard the Dorman ones are junk - I am guessing that is what LMC also sells. I got a set of adjusters off Ebay that are claimed to GM ones. the plastic nuts are green, the screw heads are also like the originals. They fit right into the holes and none broke when installed.
#9 | |
![]() Join Date: Jun 2016
87 R30 CC Dually, TBI 454, NV4500, zero rust barn find 87 Jeep Grand Wagoneer, 6.5 turbodiesel, 700R4 |
I got some at my local GMC dealer a couple of years ago. They worked well.
Just bought a set from Classic Industries, so I guess I'll find out. One thing I noticed is that different parts are listed for pre-'80 and post-'80 trucks...is it possible you might have the wrong ones?
A few Fords and a couple of Chevys ![]() |
Vaseline?
Not just you. Replaced one on a CUCV(K30 pickup variant) and had the same problem. Don't know what brand, they were some I already had. But as Kazoocruiser said, once they get tension on them from the spring, they stay put.
![]() Join Date: Oct 2014
https://www.clipsandfasteners.com/He...1&search=%20GM
Not sure which of these is correct for our trucks. At least you get more for your money. I get all my fasteners from here.
FB Page for my Seats Belts https://www.facebook.com/73-87-Chevy...9439407476735/ Restoring Seatbelts: http://67-72chevytrucks.com/vboard/s...d.php?t=809750 SOLD My 86 Build:http://67-72chevytrucks.com/vboard/s...d.php?t=654972 Past Restored Bench Seats:http://67-72chevytrucks.com/vboard/s...d.php?t=715398 PayPal link to pay for your items: https://www.paypal.me/TKCR |
#15 |
I can confirm that the pieces from Classic Industries that are supposed to be for '65-'80 trucks are not like the OE inserts and look more like the inserts you'd see to mount a license plate. Because of this, they don't clip into the core support, but they look much sturdier than the stock pieces and do get the job done.
