Old 11-24-2003, 02:14 PM   #1
pat
pat's Avatar
Last time, is a C-notch really necessary?
Im going to drop my truck 5 inches in the rear with 3" drop springs and 2" lowering blocks. Do I need to get it notched or not? I plan on doing all the suspension this winter break so Im trying to find out. I probably wont ever haul anything more than a smoker or a bumper trailer.
68 chevy half ton
68 Chevy 383/350 w/shift kit, 380hp/425ft-lbs, 4.5/5 drop, 17" TT2s
64 Cadillac Sedan DeVille
pat is offline   Reply With Quote
Old 11-24-2003, 02:22 PM   #2
BaggedC10
Under construction!
BaggedC10's Avatar
You don't have to. You'll wish you did though because it will bottom-out allot.
2001 Silverado bagged on 22's. *Sold*
BaggedC10 is offline   Reply With Quote
Old 11-24-2003, 02:23 PM   #3
PrimeredThunder
Back from the Dead
PrimeredThunder's Avatar
It shouldn't be a problem if you arent hauling any heavy loads. I know most companies sell a 4/6 drop without the notch. It isn't neccesary, but its nice to have the extra clearance.
kenny
The only Carb that matters to me is the one under my hood!
Salem, Oregon
PrimeredThunder is offline   Reply With Quote
Old 11-24-2003, 06:31 PM   #4
ShamrockCustoms
Project56 on hold
ShamrockCustoms's Avatar
test it out. remove the leaf springs from their mounts. lower the rear by the 5". now look at your rear axle tube. you should have a minimum of 3" clearance between the axle tube and the frame. if less, i would recommend getting the notch........
ShamrockCustoms is offline   Reply With Quote
Old 11-24-2003, 07:06 PM   #5
pbmcauliffe
pbmcauliffe's Avatar
I just put 2 inch blocks in the back of mine with 4" springs w/o a c-notch, and it bangs the frame quite a bit. At rest I only have a bit over 1" between the axle and frame.
pbmcauliffe is offline   Reply With Quote
Old 11-24-2003, 07:24 PM   #6
phantom dually
Project92 SWB stepside
phantom dually's Avatar
A c notch is very cheap now. Pull the bed and bolt the notch in or weld it. Really easy and straight forward.
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448
phantom dually is offline   Reply With Quote
Old 11-24-2003, 07:30 PM   #7
Izzy
Trucker.
Izzy's Avatar
You can pick up a bolt on C notch from http://www.***************** that is identical to a Western Chassis for $44.
Izzy is offline   Reply With Quote
Old 11-24-2003, 08:36 PM   #8
grnddwn
belly dragger
grnddwn's Avatar
Buy a kidney belt instead and you won't have to pull your bed
grnddwn is offline   Reply With Quote
Old 11-25-2003, 02:21 AM   #9
pat
pat's Avatar
Thanks for the input everyone. Is there an obvious place to put it on the frame, like lining it up with the axle?
fiveeightchevy, I was looking at that c-notch and it looks flat, if i remember right i think that the frames on 68s are angled right in that area?.... am i wrong?
I guess Ill go ahead and get a kit soon.
Old 11-25-2003, 02:25 AM   #10
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Mine has 6 inch drop springs in it. No c-notch,
Last weekend, I hauled a 454 big block and turbo 400 tranny in the bed for over 100 miles. It did not bottom out once.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 11-25-2003, 10:30 AM   #11
jamis
F.A.S.T. president
jamis's Avatar
The $44 dollar c-notch from suicide doors wont work on a 67-72.
The flat plate c-notch wont work on these years, because the frame has too many angles in that area. I made my own and then boxed it in. But if I had to do it again I would spend the $150 on the pre fab ones
I have 5" springs and 2" blocks and did the c-notch. I dont know yet if I need the notch, but since I'm doing a frame off, I decided to do it just in case I want to go lower later.
jamis is offline   Reply With Quote
Old 11-25-2003, 11:48 AM   #12
sactoC10
71 DELUX
sactoC10's Avatar
Similar to you, I have 3" springs and blocks but only 1.5" of block drop. I've never banged the frame, but then I don't haul anything in it other than a cooler, groceries, parts, etc... I too am thinking about a C notch, simply so I don't have to always be concerned about banging the frame.
Seems to be a simple thing to do.
sactoC10 is offline   Reply With Quote
Old 11-25-2003, 12:04 PM   #13
N2TRUX
Happy to be here
N2TRUX's Avatar
I guess the 73-87 guys forgot about the 67-72 frame in being different in the rear. No, the $49 notch won't work, but McGaughys has one for $119. Check it out....
Old 11-25-2003, 01:45 PM   #14
pat
pat's Avatar
Thanks everyone.
One more ?. Am I going to need an adjustable track bar or anything like that?
Old 11-25-2003, 01:57 PM   #15
pbmcauliffe
How much space do you have between the frame and axle?
The only way I could haul a BB and tranny w/o banging the frame is because the frame would be on the axle already
So either I have soft springs, you have stiff springs, or I have more than 4" dropped springs (in truck when got it)
Old 11-25-2003, 02:22 PM   #16
LowSeventy
I have hauled numerous heavy loads with my 6" drop Ealry Classic kit and never bottomed out yet. I asked them when I bought th kit if I needed to C-notch the frame and they said not to do it. Stan there told me if I take my rear coils out and set the frame down on the axle tubes, that there would only be a little over an inch of clearance before the rear end the bed floor. He said it's even worse with a wood floor, something like 3/4". I don't know how these guys are notching their frames without raising up their bed floors. Any input?
LowSeventy is offline   Reply With Quote
Old 11-25-2003, 03:17 PM   #17
pat
pat's Avatar
I think you might be thinking about step notches versus c-notches maybe....
http://www.*****************/index2.html
Old 11-25-2003, 03:56 PM   #18
jamis
F.A.S.T. president
jamis's Avatar
the c-notch only gives you another 2 inches, I layed the axle in the notch and I dont think I will have problems with the bed floor because the cross sills set the floor higher then the frame itself. But I wont know for sure till I get that far on my project. But when I had that problem with my 78(built it 12 years ago) which had a flip and 2" blocks and a c-notch, I had to build a box for the diff. pumpkin to clear.
Old 11-25-2003, 04:08 PM   #19
Tx Firefighter
Like Lowseventy, I have Early Classics 6 inch rear springs.
It all depends on the spring. My last truck had Eibach brand 4 inch springs in it for awhile. It would bottom out when hitting bumps going down the road. This was with KYB shocks too. I replaced them with Early Classic 4 inchers and never bottomed it again as long as I owned the truck.
Here's my clearance now, with a 6 inch springs. Got tons of room for movement.
Old 11-25-2003, 04:10 PM   #20
Tx Firefighter
Note in the above picture, the grime on the frame right above the axle is untouched. It's never bottomed.
Old 11-25-2003, 04:20 PM   #21
LowSeventy
The bed cross sills raise the floor except for directly above the pumpkin. On my 70 fleetside, the bedfloor sets right on the frame above the rear end. Additionally, the upper shock crossmember will interfere with the snout of the rearend.
Old 11-25-2003, 04:21 PM   #22
pbmcauliffe
Looking at your picture I can see that you have alot more room than I have. I wonder if the previous owner used something other than 4" springs, because with whatever springs are in there, and a 2" block, the axle is only about 1" away from the frame.
Old 11-25-2003, 05:54 PM   #23
SCOTI
SCOTI's Avatar
Dang guys.... I estimated my 68's rear drop @ 6-7" but after looking @ TxFirefighters pic, either I'm more than 7 or he's less than 6.
At typical ride height @ 30-35psi, the top of my rear end housing sits just inside the c-notch in the framerail.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 11-26-2003, 03:14 AM   #24
Hotrod70C10
Low & Slow
Hotrod70C10's Avatar
Looks like a 6" drop on tx firefighter's truck to me. Mine looks to be about 2 inches higher than that and I have a set of 4" springs.
70' C-10 LWB Fleetside
4.5/6 drop
Hotrod70C10 is offline   Reply With Quote
Old 11-26-2003, 08:12 PM   #25
pbmcauliffe
[Thread hijack on]
Okay, if TxFF's is a six inch drop and has a good amount of room between the axle and frame, any ideas of how much drop mine is. The previous owner said it had 4" McGaughys springs, then I added 2" blocks so it should be 6" total, but like I stated earlier I only have an inch between axle and frame, any ideas why such a difference.
Rear tires are 275s on 10" rim @32psi
[Thread hijack off]
