4-6 drop and exhaust
Any problems with the exhaust being run under the trans crossmember with a 4-6 drop?
OLDIRONRACING |
Re: 4-6 drop and exhaust
I,d go over, looks ugly with pipes hanging down anyway
meowMEOWmeowMEOW
I'm a little lower than that and my setup was run below the xmember (until I could built a raised one). Its fine most of the time, but running it above would gain ~3" of clearance that would be nice to have.
Also, if you run it below you can juuuust about see it from the side of the truck.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
Have it up and over right now but worried about the fuel line is about 1.5 inc away from it and the trans cooler lines. Thought about useing some heat sleeves on the lines. Thoughts on this?
OLDIRONRACING |
I would keep it above the x-member & wrap the exhaust pipe where it's close to the fluid lines along w/wrapping the fluid lines where they're close to a heat source.
Any suggestions on what to wrap the lines with? That work so.
OLDIRONRACING |
#7 | |
http://designengineering.com/
