Old 02-16-2019, 03:20 PM   #1
Isaiah92260
Isaiah92260's Avatar
63 vacuum advance ID
I just got this vacuum advance for my 62’ 235.
Can anyone explain to me how to install it? Also what is that indicatior for that says 10-10 & A|R
Thank you!
Isaiah92260 is offline   Reply With Quote
Old 02-17-2019, 01:17 AM   #2
j.kirn
Re: 63 vacuum advance ID
Pull the distributor out remove the old 1 and put the new 1 on the way you took the old 1 off
j.kirn is offline   Reply With Quote
Old 02-17-2019, 01:49 AM   #3
The Rocknrod
Moderator
The Rocknrod's Avatar
Does this help? Looks like your missing the clamp that goes around the distributor shaft(second pic).
Old 02-17-2019, 01:39 PM   #4
paulspickupparts
Looks like the repo is missing parts. Maybe you can move some of the parts over from the old one .
paulspickupparts is offline   Reply With Quote
Old 02-17-2019, 03:20 PM   #5
Isaiah92260
Yes I’m missing that stud that is pressed or welded on the vacuum.
So what I did was dropped a cutter pin and twisted around the edge so that it sat in there tight. So that when the vacuum advances the distributor, it’ll get a full and accurate pull/advance.
What does A-R / 10-10 mean though? And what do I do with that?
Old 02-17-2019, 08:24 PM   #6
The Rocknrod
Moderator
Advance/Retard and degrees.
