11-24-2003, 06:28 PM | #1 |
Insert funny comment.
Air tank mounting locations
Im fairly new to the air ride suspension stuff. Is it possible to have air bags for front and rear and mount all the equipment under the bed? I do plan on relocating my gas tank to the frame as well... just wondering if there is room for an air ride suspension while im planning my truck build up.
------------ - Mark -My Build Thread... -68 C10, LT1 - Undergoing Frame off resto -86 IROC-Z T72 turbo 355, M6 -70 Camaro http://www.iroc-ss.com |
11-24-2003, 11:29 PM | #2 |
Happy to be here
Mines not a 67-72, it's a 77 but there shouldn't be that much difference back there. Here's what was done on mine....
Tank shot-
11-24-2003, 11:30 PM | #3 |
Happy to be here
Compressor shot-
11-24-2003, 11:30 PM | #4 |
Happy to be here
Big Red valves-
11-25-2003, 12:24 AM | #5 |
Hmm from seeing your frame shots, Im guessing the answer is no if I plan on relocating the gas tank.
11-25-2003, 01:34 AM | #6 |
thats exactly what I was thinking ... I would love to put my tanks and compressors there ... but there is already a poly Blazer tank there.
11-25-2003, 03:23 AM | #7 |
I HAVE 67 AND 5 GAL TANK IT FIT ALONG FRAME RAIL UNDER CAB DRILLED AND WELDED NUTS TO TANKS LEGS
11-25-2003, 11:17 AM | #8 |
Happy to be here
Yeah, if your putting a Blazer tank in the rear, it won't work like mine. Personally I woudn't put my gas tank back there. The main reason we removed the spare tire was it hung down too low. I would think the gas tank would too.
We mounted the air tanks on my Blazer outside the frame in the rear. They plan to raise the rear floor, and make a smaller gas tank to prevent it from dragging... Here it is now...
11-25-2003, 11:18 AM | #9 |
Happy to be here
Another view-
11-25-2003, 11:19 AM | #10 |
Happy to be here
It looks like valley 67 has you answer if your set on a tank in the rear...
11-25-2003, 01:40 PM | #11 |
belly dragger
I put mine in the back on either side of the tank like N2TRUX
11-25-2003, 03:13 PM | #12 |
Back from the Dead
i plan on relocating mine, but i want to wait until I upgrade to a 12 gallon tank and engine driven compressor. Right now i've got to listen to my 6 gallon and my compressor mounted behind the seat.
Kenny
The only Carb that matters to me is the one under my hood! Salem, Oregon |
11-26-2003, 12:08 AM | #13 |
Project92 SWB stepside
Anyone ever thought of boxing in your frame rails and using them for you air tanks. Put a few bungs in and you set.
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448 |
11-26-2003, 12:16 AM | #14 |
belly dragger
Seen it done its alot of work though
11-26-2003, 12:30 AM | #15 | |
11-26-2003, 01:29 AM | #16 | |
Happy to be here
I guess the floor on the 67-72 cab won't allow you enough space to mount it under the bed/cab like the 73-87's do. Is there room to put a custom built tank along the frame like that? |
11-26-2003, 01:31 AM | #17 | |
Happy to be here
11-26-2003, 02:26 AM | #18 |
MY TANK MOUNTED UNDER CAB NO MODS AND STOCK CAB MOUNTS..
11-26-2003, 11:35 PM | #19 |
aka Crusher, Crushergmc
I was thinking of mounting mine inside the "rocker box" on my 70 Jimmy. Probably won't because so the work involved.
"KEEP IT DOWN!" 70 Jimmy 454 2wd 56 GMC Big Window "It's funny till someone gets hurt, then it's freakin' hilarious" |
11-27-2003, 12:19 AM | #20 | |
Happy to be here
11-27-2003, 12:24 AM | #21 |
ILL TAKE PICS THIS WEEKEND
11-29-2003, 12:21 AM | #22 |
1
11-29-2003, 12:22 AM | #23 |
2
11-29-2003, 12:23 AM | #24 |
belly dragger
Will it be in the way of your exhaust?
11-29-2003, 12:23 AM | #25 |
3
