02-19-2019, 04:33 PM | #1 |
any secrets to removing a arm shaft bolts
Have my upper and lower a arms out for a front suspension rebuild. Everything is out and a part, except I can't get the lower a arm shaft bolts out. I have a 2 foot 1/2" breaker bar with the shaft in a vice....and the breaker bar bends to a uncomfortable amount. I had to get a 1 5/8" 3/4" socket with a 3/4 to 1/2 reducer. That alone set me back 30 bucks! Maybe a cheater bar???? Probably snap the 1/2" breaker bar?
1969 C-10 LWB SS 1969 Camaro Pro Tour 2002 Camaro SS LE Rag Top #937 |
02-19-2019, 05:14 PM | #2 |
Re: any secrets to removing a arm shaft bolts
Dang! Righty Tighty.... LOL jk Use some penetrating oil and an impact. Mine came loose using a large pipe wrench and a BFH. -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
02-19-2019, 07:00 PM | #3 |
LOL.....Thanks for those instructions...I will not forget them:
Got them off.....found my 22 year old son and a cheater bar off my jack handle. Still almost pulled my vise out of the bench
02-19-2019, 07:04 PM | #4 |
Ha ha, I know the pain! Glad you got them out when I did mine I ended up bolting them back on with the U bolts on to the truck and getting them loose that way.
02-19-2019, 07:07 PM | #5 |
While you have it torn apart, upgrade to the 9/16" lower control arm u-bolts for safety. The original ones liked to snap when reversing with the wheel cranked all the way in either direction. Dorman 13503 are the ones you want. Other vendors have them as well.
72 C10 lwb fleetside -stock 350/350 combo |
02-20-2019, 09:40 AM | #6 |
Doing dame thing to my 72. Wound up cutting old bolts off and as previously mentioned upgraded to the 9/16 . summit has them for 12$.
02-20-2019, 10:23 AM | #7 |
What are the torque specs for the upper and lower a arm shafts? I have seen different numbers for new vs original?
02-20-2019, 10:33 AM | #8 |
Good luck with this question ! Finding the correct torque is tough. Service manual is misprinted. New vs original makes sense since the original would already be splayed out in the a arm collar. Using the original a arm may accept less torque ? I called the "Moog Experts" & they were about as much help as a wet paper bag. "Gee I dunno" they said. One friend suggested torqueing till still movable and tacking the heads so they don't back out ? Is it half ton or three quarter ? A1Auto sells 3/4 pairs with ball joint for about $100 pre torqued. Again, Good Luck.
02-20-2019, 10:35 AM | #9 |
"once assembled use some Dykem torque seal to mark the installed position and it gives you a good quick check to make sure they haven't moved / loosened up on you"
Great advice ! Thanks Grumps. |
02-20-2019, 10:24 AM | #10 |
The secret is to loosen them BEFORE you take them off the frame , Once you have the ball joints loose and remove the spring use the weight of the frame to your advantage and loosen the shaft bushings . I used a 20" Cresent wrench and a cheater bar to remove the shaft bushings ,Then once they are loose enough that you don't have to wrestle with them in a vice remove the A arms from the frame . Easy Peasy , When installing them mount the new shafts to the frame first and locate the pin and torque the lower new 9/16 Ubolts , the upper shaft can just be slid into place and then install the A arms and the new bushing caps again using the frame instead of assembling them with a bench vice . I used all new Moog parts and cleaned /primed and painted so the last thing I wanted to do was clamp them in a bench vice . It was easy and fast and no scratches or marred up parts . once assembled use some Dykem torque seal to mark the installed position and it gives you a good quick check to make sure they haven't moved / loosened up on you
https://www.youtube.com/watch?v=h5fXwNzPEso https://www.aircraftspruce.com/catal...iABEgIOwPD_BwE ( Orielly's $9.49 for the Dorman 13503)
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop Last edited by Grumpy old man; 02-20-2019 at 10:34 AM. |
02-20-2019, 10:46 AM | #11 |
Thanks for the heads up on finding correct torque specs!
And Thanks for the installation procedure to the arms Grumpy...I noticed in your pics your lower a arm has what looks like a sway bar bushing? Asking because my 69 1/2 ton does not??
02-20-2019, 11:00 AM | #12 |
Factory sway bar , they are 1 1/16" and later 1 1/4" the mounting holes are already in your factory A arms and frame . You can find them on the parts board . The frame brackets are available aftermarket for stock stance and they make a set of brackets for a lowered truck using a factory sway bar also . I used Energy suspension bushing on this truck build .
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop Last edited by Grumpy old man; 02-20-2019 at 11:11 AM. |
02-20-2019, 11:13 AM | #13 | |
Thanks for the explanation I see the 2 holes for the bushing in my lowers...I bought a 1 1/4" from CPP and they mount differently then yours. Wish I would of known this particular way before i bought mine.I like your set up more.
02-20-2019, 11:15 AM | #14 |
These are the specs I use . I always use the Dykem just to be sure on suspension/ steering .
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
02-20-2019, 11:18 AM | #15 |
Grumpy, Where does it show the steel bushing C10 torques ?
02-20-2019, 11:32 AM | #16 |
I found these in another thread from the factory manual
http://67-72chevytrucks.com/vboard/s...d.php?t=471554
02-20-2019, 11:33 AM | #17 |
I believe the specs supplied above states 115 ft-lbs for a arm bushing bolts.
02-20-2019, 11:59 AM | #18 |
Do the holes have to be drilled out for the larger u-bolts?
George |
02-20-2019, 12:02 PM | #19 |
Yes , Minor , Just run a 9/16 drill up thru the holes from the bottom .
02-20-2019, 12:05 PM | #20 |
Possibly. Some trucks do, some don't. Mine did. Use a 9/16" drill bit, you won't have to do much an it's not hard
