Old 02-22-2019, 12:51 PM   #1
bean
Stubborn ball joint
Redoing front-end and am in the final stretch. My problem is the passenger side lower ball joint just will not break free. Went to harbor freight this morning and got a bigger sledge. Just thought I would ask is there anything else I could try? Thanks guys.
bean is offline   Reply With Quote
Old 02-22-2019, 12:54 PM   #2
weq92f
weq92f's Avatar
Re: Stubborn ball joint
Go borrow the tool from Autozone and press it out. You'll need that same tool to press the new one back in!
Hth,
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is online now   Reply With Quote
Old 02-22-2019, 12:57 PM   #3
68 P.O.S.
Yes, this. And the ball joint press is easy to use.
72 C10 lwb fleetside -stock 350/350 combo
68 P.O.S. is offline   Reply With Quote
Old 02-22-2019, 12:58 PM   #4
AussieinNC
Moderator
AussieinNC's Avatar
If you have the suspension arm hanging free, it is most likely moving back and forward with the hammer blows...
Put a floor jack under the ball joint and take a little weight up on the jack....
I use a pickle fork and 5 LB hammer...so long as I am not reusing the ball joint...
Hope this helps..
Family and country before all others...
2006 Chevy Silverado (Daily Driver)
2012 Chevy Equinox
AussieinNC is offline   Reply With Quote
Old 02-22-2019, 01:01 PM   #5
bean
Thanks. I should have made it clear I am replacing control arm and all.. Problem is brealing old one free from the spindle... It just doesn't seem to move
Old 02-22-2019, 01:04 PM   #6
weq92f
weq92f's Avatar
Use the hammer against the knuckle swinging perpendicular to the ball joint shaft. Give it a good hit and the thing should just slide right loose. Careful of the spring though.
Either that or use a pickle fork to separate the two pieces.
Hth,
-klb
Old 02-22-2019, 01:06 PM   #7
bean
The knuckle on the spindle?
Old 02-22-2019, 01:08 PM   #8
weq92f
weq92f's Avatar
Sorry, the thick metal boss that the ball joint shaft is stuck in. Hit that perpendicular to the ball joint shaft. Hit it hard.
-klb
Old 02-22-2019, 01:07 PM   #9
AussieinNC
Moderator
AussieinNC's Avatar
Yep...thats what I assumed you were attempting....
Be safe though....make sure the lower A arm is on a floor jack....to take the weight of the spring load etc...
I assume you have the shock absorber off of it already....
Sometimes its necessary to have a solid hammer against the back on the balljoint hole on the spindle then hit the other side of the spindle....to shock it out....
2012 Chevy Equinox
Old 02-22-2019, 01:36 PM   #10
bean
Thanks I will try that. Never had this happen before☺
Old 02-22-2019, 01:40 PM   #11
bs46488
I just re-did all the front end components on my truck.
It took a big hammer and lots blows to get the ball joint free from the spindles....but eventually they broke free.
Project Engine Stand 1972 SWB conversion: http://67-72chevytrucks.com/vboard/s...d.php?t=673914
1970 Nova: http://67-72chevytrucks.com/vboard/s...d.php?t=708161
bs46488 is offline   Reply With Quote
Old 02-22-2019, 01:52 PM   #12
68 P.O.S.
You may have to use 2 pickle forks as well.
Old 02-22-2019, 01:55 PM   #13
bean
2 forks? What stack them?
Old 02-22-2019, 02:03 PM   #14
bean
Never mind realized what you mean lol
Old 02-22-2019, 02:05 PM   #15
68 P.O.S.
Yes, you'll have to stack them. I've had to do that before when things were being a pain.
Old 02-22-2019, 02:19 PM   #16
Getter-Done
Getter-Done's Avatar
If you like buying tools like I do.
Video with air hammer and pickle fork.
https://www.youtube.com/watch?v=fxhfSBGs2ls
Tool kit for air hammer or you can just use a hammer.
https://www.amazon.com/HFS-Piece-Joi...productDetails
The early bird gets the worm,
84 Chevy K-20
Old 02-22-2019, 02:34 PM   #17
HO455
HO455's Avatar
If things are particularly stubborn apply some soft heat with a Propane or Mapp gas torch to the spindle. Cleaning all grease and removing the brake hose for fire safety are required! Having the Pickle Fork in position and preloaded will help. The idea being to heat the spindle and get the ball joint loose before the heat from the spindle is conducted to the ball joint. A hundred degrees difference between the two pieces will give you a thousands or two of clearance.
RIP Bob Parks.
Old 02-22-2019, 11:26 PM   #18
Pro299
Junior Member
Just did this last year. I had a stubborn one too. I got the pickle fork under it good and tight, then whacked the knuckle with a two pound hammer just above the fork. Popped right loose. Like others have said, be safe. Leave the nut loose on the joint to keep everything together until you're sure you're ready to deal with the spring.
Pro299 is offline   Reply With Quote
Old 02-23-2019, 02:21 AM   #19
kwmech
Let the arm hang without the floor jack touching it, but still underneath it about an inch or 2. Frame on the jack stand. Loosen the nut about 3-4 turns and leave it on. Hit the side of the spindle. The vibration and the pressure of the spring will jack it free. After it separates, then use the floor jack to raise it up enough to spin the nut the rest of the way. Lower floor jack slowly until the spring pressure is off and the ball joint is free.
Old 02-25-2019, 01:24 PM   #20
bean
Thanks for all the advice guys. Did what you said klb about hitting it perpendicular. Then used the fork and my new 8 lbs sledge... Came free after the 2nd hit. Now to get it aligned and put some miles on it. Again thanks to all for the advice.
