Old 02-24-2019, 10:29 AM   #1
44SAA
Evaporator Core
My AC evaporator needs replacing. Can anyone confirm if I can simply remove 1/2 of the fiberglass case facing the engine? I’m really not wanting to remove the entire assembly including the blower fan. Thanks
44SAA is offline   Reply With Quote
Old 02-24-2019, 11:22 AM   #2
100%Chevy
Re: Evaporator Core
Yes,you can!
Be careful of the bolts coming from the other side as they usually are hard to get the nuts off and will spin in the plastic housing,tearing the plastic on the inside.
Mike.
100%Chevy is offline   Reply With Quote
Old 02-24-2019, 01:56 PM   #3
sweetk30
sweetk30's Avatar
Re: Evaporator Core
i remove all under coating from threads .
then run a thread chaser with lube down the long bolt threads .
clean off with brake cleaner and vary slow with a hand wrench see if the nut comes loose .
if not little heat and you prob good to go .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 02-24-2019, 02:02 PM   #4
44SAA
Re: Evaporator Core
This is good info. I can clearly see the 2 screws on the top of the assembly. How many are on the bottom of the box and are they hard to access?
