Old 02-25-2019, 10:16 PM   #1
Short 3/4
T221 lube opinions
Just finishing up a rebuild of my T221 and wondering if anybody out there has opinions on what lube is best to keep it happy. I keep a bucket of both GL 4/5 and Synthetic gear lubes for my old junk, and would tend to use one or the other unless somebody has a better suggestion.
For the record I always use a mag plug and change the lube every two years in all the trans/x-fers and diffs I own.
Thanks for any input
Tom
65 short stepside K10
292-SM420-T221
8 lug closed D44 front
NoSpin HO72 4.10 rear
Short 3/4 is offline   Reply With Quote
Old 02-25-2019, 10:19 PM   #2
sweetk30
sweetk30's Avatar
Re: T221 lube opinions
my old gear to gear stuff i do 1/2 qt of lucus oil stabilizer and top off with dino grade oil .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 02-27-2019, 07:26 PM   #3
Short 3/4
Thanks for the input
Guy who rebuilt mine recommended not using synthetic, so wondering what others have had good luck with.
Never used oil stabilizer, I'll have to read up on it
292-SM420-T221
Old 02-27-2019, 07:57 PM   #4
'63GENIII
'63GENIII's Avatar
Thats interesting. The 221 makes a fair amount more heat than say a 205 or just about any of the newer T Cases. I would think that the synthetic would have better heat withstand capability than the dino.
IIRC I ran 85w - 140 wt Valvoline when I had mine.
Ive been synthetic for the past couple of years with the 205 though. Its a mix of Amsoil MTL and Redline Shockproof Light.
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 02-28-2019, 08:33 PM   #5
jeffahart
jeffahart's Avatar
I would just put the same oil you're putting in the 420. Keep it the same and you can just get the GL/4. I've been getting the Sta-Lube off Amazon.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
j
White K20
jeffahart is offline   Reply With Quote
Old 03-10-2019, 02:15 PM   #6
vectorit
What?
vectorit's Avatar
I stick with plain 90w gear oil.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 03-11-2019, 10:33 PM   #7
Short 3/4
Appreciate you all sharing opinions,
Thanks,
Tom
292-SM420-T221
Old 03-12-2019, 04:49 AM   #8
mikelom
A straight 90 should work fine.
mikelom is offline   Reply With Quote
