Old 11-25-2003, 12:05 PM   #1
Mike Culpepper
Red
Mike Culpepper's Avatar
elec. choke Q's
The elec. choke on my '72 isn't working and I was hopefully going to get a chance to look at it in the next few days. I have a quadrajet, and there is one red wire going to a spade connector on the choke body. If I hook up a volt meter, I assume I should be getting power to this red wire in any "key on" position, or is it only when starting? Assuming there is power, to the wire, what would be the next thing to check? ANyone know of any links to sites for troubleshooting electrical chokes?
Mike
'72 Cheyenne LWB 350/350
"The sun don't shine on the same dog's ass all the time." - Catfish Hunter (commenting on why he was not able to pitch another perfect game).
Mike Culpepper is offline   Reply With Quote
Old 11-25-2003, 12:35 PM   #2
JimKshortstep4x4
Talking
Does the choke close or does it not open?
With power to the choke and it still will not open then the choke is bad and will need to be replaced.
The electric part of the choke warms up the bi-metallic spring and causes the choke to open. The spring closes the choke when it is cold.
Jim
Old 11-25-2003, 12:47 PM   #3
tom hand
CCRider
tom hand's Avatar
You should have power when the key is in the run position...I wouldn't want to have power to it in the acc position. Check it in the morning when it is cold...the choke should be completely closed...this adjusted by the black houseing where the wire plugs in...loosen the screws and turn the houseing till it is completely closed. Now crank the engine...within a few seconds the choke pulloff should open th choke till you have a 1/8 to 1/4 inch gap....depending on what runs best...this is adjusted on the pull-off. And when the motor is warm it should be fully open. The electric part turns the choke off...it should have no effect on it setting....The choke on those ussally works best if you press the pettle one time fully to the floor to set it and then crank....sometimes if you push the gas pettle too much it will kick the choke off...Good Luck
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
tom hand is offline   Reply With Quote
Old 11-25-2003, 01:24 PM   #4
Mike Culpepper
Red
Today is the first real ccol day we've had in Houston, so I haven't even looked at it yet. I will and will get back to ya'll. BTW I typically, put the pedal all the way to the floor, then back off 1/2 way then crank.
Thanks for the info.
Mike
Old 11-25-2003, 08:55 PM   #5
86SILVERADO
86SILVERADO's Avatar
In the A.M when you check it make sure you blip the throttle first and then get out to look to see if it closed the choke. The choke is fully open when you get home after driving and stays that way until you blip the throttle in the morning to let it close.
86 Silverado C10 back to 305 power!
67 C30 Dually Dump, with 350 transplant, Rockhauler
05 Duramax 3500
"If at first you don't succeed, try a bigger hammer"
Member of the 1-Ton club!
86SILVERADO is offline   Reply With Quote
Old 12-06-2003, 10:16 AM   #6
Mike Culpepper
Red
Well I finally got a chance to look at the choke. The top "butterfly" closes to about 1/8-3/16 " after pushing the excellerator down. But the rpm's of the engine don't increase. There is 12 v to the wire. Ideas?
Mike
Old 12-06-2003, 01:25 PM   #7
dwaite72lnghrn
check the black ground wire make sure it is to a good ground. Then when it is cold and the choke is closed look at the drivers side of the carb and make sure the idle screw is on one of the steps of the choke positioner. If it is real cold out it should be on the highest step. If the engine warms up the choke should move the positioner down the steps as it warms up.
72 longhorn c30 502BB/th400/fact air/4.11rear/ custom camper
72 bug(the better half's) under reconstruction
2009 HHR aqua blue
71 GMC k20 350/sm465
2009 Chevy hd3500 6.6 Victory Red crew cab dually
Dave & Jeanne
dwaite72lnghrn is offline   Reply With Quote
