03-04-2019, 10:28 PM | #1 |
Advice on where to get a banjo fitting
Looking to replace the flex hose banjo fittings on the front drum brakes of my 1970 K10 1/2 ton. They are tapped to accept a 7/16-20 male thread on the flex line and use a 7/16-20 banjo bolt to the brake cylinder. They are a little odd in that the fitting creates a 45 degree angle between the line and the wheel. Can't seem to find anywhere! Also, if anyone went to a "plan B" on this, please let me know what you did. I have one that I could probably re-use, but out of luck on the other side.
03-05-2019, 04:31 PM | #2 |
Who Changed This?
Re: Advice on where to get a banjo fitting
This is getting views but no info. Maybe try a brake shop? Meaning a store that specializes in brake parts rather than the usual suspects.
03-05-2019, 04:58 PM | #3 |
IIRC, the aftermarket hoses bypass that fitting, can't remember. If that fitting goes to a short brake line then to hose, the aftermaket hoses bypass that. Not sure, don't take my word for it. (I know, I'm a lot of help!)
http://weblink.carquest.com/acl/?mfg...umber=BHA73273 |
03-05-2019, 06:04 PM | #4 |
Why replace the banjo fitting? Get new washers, and unless they've been mangled they last forever.
My Chevy Truck Project Build Thread '62 Ranchero - 200 I6, 3-on-the-tree, power nothing. '71 LeSabre - 455 Stage 1, power everything. |
03-05-2019, 07:00 PM | #5 | |
I'm pending my 3rd set of replacements, and of course none have that fitting. None have quite fit right into the cross member brackets, though I hear Dorman's do. Rebestos pending, if those don't work, I just recalled a local can set me up. Should have done that to begin with, the fittings are nuts.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
03-05-2019, 09:59 PM | #6 | ||
"I ain't nobody, dork."
Try looking at Inline Tube (www.inlinetube.com). They have a lot of the brass fittings and hard to find brake parts.
Gary
03-06-2019, 11:47 AM | #7 |
I find the best place is at a good bluegrass festival.
There's usually a vendor there that can build you a banjo that's comfortable to play
1970 C10 LWB Stepside 1971 Dodge Dart 1993 Buick Roadmaster Estate Wagon |
