Old 03-25-2019, 04:15 PM   #1
cerial
cerial's Avatar
Hydroboost line question
I have a 87 which i am swaping in a 02 Silverado 5.3 and have 04 van hydroboost. I cut the firewall out of the 04 taking the boost and pedal pump and lines as a unit.
I am going to make some pedals maintaining the 04's ratio with a bell crank letting me go 90 and have a long rod pushing the hydroboost master which will be located behind the glove box.
Line wise can I eave the power steering pump in the 5.3's stock location on the drivers side with long lines feeding the hydroboost?
Or would i be better off moving the pump to the passenger side and have shorter lines feeding the hydroboost and longer lines going to the steering box?
Placing it on the passenger side allows for shorter high pressure line lengths. But if it is not going to matter much then I would perfer to keep the pump in the stock location not messing with the belt at all.
I dont have any extra steering boxes and should replace the one i am running now. Is there one I should run with that 04 pump/master or will one for a 87 be good.
1991 Metro commuter
1991 s10 future project truck
1987 V10 backup daily/junk truck
1985 K20 Winter beater
1991 R30(squarebody) c/c flatbed towrig
1994 s10 80"wb custom build
cerial is offline   Reply With Quote
Old 03-25-2019, 06:52 PM   #2
mongocanfly
mongocanfly's Avatar
Re: Hydroboost line question
I kept my stock steering box on my 81and the 02 LS pump is just fine running it and the hydroboost...I'd keep it on the driver side...just to make it easier to plumb the steering box...the longer lines to the hydroboost wont matter
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 03-25-2019, 11:40 PM   #3
cerial
cerial's Avatar
Thank you
1991 Metro commuter
Old 07-19-2021, 08:07 AM   #4
mcmlxix
Collector of Projects
mcmlxix's Avatar
Can someone confirm the Hydro-Boost Lines:
HI input - FROM Power Steering Pump
HI Output - TO Power Steering Box
LO Output - RETURN to reservoir
Also, can someone confirm the Front Port on the master cylinder is for the front brake circuit and rear for rear?
I'm think it's logical but I want to make sure before I actually start bending hard lines....
I'm posting here in this group but swapping this setup into my 72 K5 using one ton axles and 4 wheel disc brakes ....
Rich
1972 K5 Blazer CST Click HERE
Old 07-20-2021, 02:16 AM   #5
mcmlxix
mcmlxix's Avatar
Someone was nice enough to send me a link with some info … here are diagrams/photo if it helps anyone else....
Rich
Old 07-20-2021, 07:14 PM   #6
hatzie
Moderator
hatzie's Avatar
I don't believe the front and rear make any difference at all on a T800 disc/disc master cylinder.
The ABS controller takes care of brake bias on the T800. The 67-72 trucks used a combination valve to bias the brakes.
The stock 67-72 combination valve is setup to bias disc drum setups. Make sure your combination valve is setup for 4 wheel discs.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
