03-26-2019, 11:34 PM | #1 |
Noisy DBW Throttle Body
I'm trying to wrap up my swap and started it for the first time last weekend. I noticed that when I turn my key into the run position, my DBW throttle body powers up or engages loudly. The engine, tac and peddle came from the same truck. I drove that truck for 6 months and never really heard it before.
Any thoughts? |
03-27-2019, 04:05 AM | #2 |
Re: Noisy DBW Throttle Body
It's normal for them to make some noise when you first turn them on. How loud is it?
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
03-27-2019, 06:45 AM | #3 |
If you have the air intake off you can here it pretty good . This is normal . It does a little quick test open and close to check to see if there is a problem with the tb binding . If it detects a slight resistance it will throw a code and will not open the tb after starting the engine .
This is GM fail safe test so you dont have a stuck open tb and a run away engine . |
03-27-2019, 10:52 PM | #4 | |
03-27-2019, 10:51 PM | #5 | |
You can here it at the very beginning of the video posted to my ig account: https://www.instagram.com/the_not_asian_caucasian/ To me it's as loud as a starter engagement. But, you can put your hand on the tb and it's definitely it. |
03-28-2019, 12:34 AM | #6 |
Thats perfectly normal. Its a sound you really get used to when tuning them, as evey time you load a new calibration it cycles the computer.
03-28-2019, 06:05 AM | #7 |
yes, normal sound out of mine. running that way for almost a year, no problems.
Jay Gesner Atlanta, GA 1985 C10 Long Bed 4X2 LS 5.3, 4L60E Father/Daughter Project |
03-28-2019, 12:02 PM | #8 | ||
Thanks guys. I just never noticed it in the other truck. |
