Old 04-06-2019, 08:23 PM   #1
Chris74
long bed to short bed question
I need to know how much to cut out of the frame I have a 79 one ton and yes I have used the search on here.
Chris74 is offline   Reply With Quote
Old 04-06-2019, 08:33 PM   #2
Mathew21
Mathew21's Avatar
Re: long bed to short bed question
One of these threads might help you.
http://67-72chevytrucks.com/vboard/s...d.php?t=612254
http://www.73-87.com/7387garage/chas...lwb_to_swb.htm
It only has original paint once
Mathew21 is offline   Reply With Quote
Old 04-06-2019, 08:55 PM   #3
Chris74
thanks I have been told to cut 14 inches and some one said 19 or 20 so I wasn't sure
Old 04-07-2019, 04:53 PM   #4
mMad Dawg
Yes you cut 14" from in front of the wheels and up to 6" from the back .I would wait til you get your box cut down before you cut the rear because for some reason the rear of the frames are different. Just cut off as little as you can. That leaves more room to mount a bumper.
mMad Dawg is offline   Reply With Quote
Old 04-07-2019, 05:33 PM   #5
Chris74
I have a short bed for it so I will not be cutting the bed down
Old 04-07-2019, 06:59 PM   #6
sweetk30
sweetk30's Avatar
make sure to do lots of measuring as true c/k 30 1ton frames are taller from the firewall back till almost the rear 2 box bolt area .
i needed to repair 1 k30 frame and was going to use a c10 rear section from the center of the rear axle back and it was to short to match up .
so the info you read use it as a guide and note the height difference in the k30 frame .
good luck and keep us posted . here is mine were i took a crew cab k30 and cut it down to a std cab spec and welded it up . http://67-72chevytrucks.com/vboard/s...d.php?t=755514
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
