04-14-2019, 01:23 PM | #1 |
fancy suspension removal tools - spindles, control arm shafts
From the perspective of getting older, and wanting to work smarter, not harder...
Are there any fancy tools/press kits or something out there that make it easier replacing upper and lower control arm shafts? without getting a big standing press? I found something online called the "RideTech Bushing Installation & Removal Tool" - there's a youtube video. Maybe this is our secret weapon. anyone used it? What about spindles? We can manage ball joints with the ol' c-clamp press. That's what cheater bars and patience are for. But, hey maybe there's some new-fangled thing there too. Last edited by turpentyne; 04-14-2019 at 01:35 PM. |
04-14-2019, 04:32 PM | #2 |
Re: fancy suspension removal tools - spindles, control arm shafts
I am getting ready to tear apart my front end so I am waiting for information from the experts here.
1970 C10 8' Fleetside, L6 250, 3 on the Tree. The most basic of pickup trucks! |
04-14-2019, 04:34 PM | #3 |
the factory shafts dont have pressed bushings they screw in just a big socket and impact wrench
04-14-2019, 08:02 PM | #4 |
ah... checked it out.. looks like a 1 3/8 and 1 5/8 socket will do the job.
For some reason, I still seem to remember it not being "that" simple? maybe it is? |
04-14-2019, 08:41 PM | #5 |
Who Changed This?
I had my 300-pound son stand on the lower a-arms while I unscrewed those nuts, using a 3 foot long handle. Maybe that's what you're thinking about it not being "simple".
04-14-2019, 09:29 PM | #6 |
I tore my drivers side down last night on my 68. I have never done it before and it wasn't to bad. It took about an hour and a half with just basic hand tools and a 3/4"breaker bar and the big sockets. just used the floor jack to preload the lower a-arm before I removed the spindle nut. A big hammer got it loose. Lots of info on this in this forum.
04-14-2019, 09:48 PM | #7 |
I got one of these to change ball joints. Actually went harbor freight for it. Strong and works well.
https://www.ebay.com/itm/4-In-1-C-Fr...QAAOSwV0NbGe-v
2003 Dodge 2500 1969 C10 2014 Camaro SS/RS/1LE |
04-15-2019, 01:15 PM | #8 |
A large pipe wrench is cheaper than the big socket and works just as well. Plus you can use it later for other projects, where that socket will likely not get used again! Break those loose while the arms are still attached to the frame. Hth, -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
04-15-2019, 07:40 PM | #9 |
I have done a few.
Big muscles A good 3/4" breaker bar or ratchet The right sockets for the lower shafts A short handle sledge to get the ball joints and tie rods loose from the spindle and center link A good grinder An air chisel Ball joint press Good grease gun Some 90 degree zerk fittings for the ones you cant get the gun on I tried to use a huge crescent wrench and pipe wrench to replace my control arm shafts. That was a nightmare. Go to harbor freight and get the right stuff - you will only use it a couple times.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
04-15-2019, 11:15 PM | #10 |
My 1 5/8 & 1 3/8 sockets I got at oreillies auto parts for about $10.00 each. Auto zone also has them for about the same price. For what we spent on the front end rebuild and front brake conversion this is nothing especially if you mess up the new stuff with the wrong tool. You can "borrow" the pitman arm puller and ball joint press at the same places for a deposit. Just make sure they are in good shape and not bent before you take them or make sure there is documentation stating this or you could end up owning the tool.
