Old 04-14-2019, 04:07 PM   #1
jlampka
Do I need hi temp paint for my air cleaner?
I have a 1972 GMC Longhorn with 402ci big block recently purchased. The air cleaner housing and cover could use a fresh coat of paint to spruce up the engine bay. Am I better off with high temp paint? Just checking so I don't have to paint twice. Thanks for any input
jlampka is offline   Reply With Quote
Old 04-14-2019, 04:33 PM   #2
bill3rail
bill3rail's Avatar
Re: Do I need hi temp paint for my air cleaner?
Nope.
1970 C10 8' Fleetside, L6 250, 3 on the Tree.
The most basic of pickup trucks!
bill3rail is offline   Reply With Quote
Old 04-14-2019, 04:55 PM   #3
bill3rail
bill3rail's Avatar
I actually painted mine with Rustolium dark grey textured paint and it looks pretty good.
Old 04-14-2019, 06:50 PM   #4
Terrysch
You don't need high temp paint for the air cleaner.
But highly recommend that you use an engine paint.
Engine paints are formulated to be more resilient in the engine compartment including being resistance to gas, oil and chemicals.
I actually just researched, because I am putting an OEM/original air cleaner back on my 1972 GMC Jimmy. I had a cheap aftermarket chrome one that is rusting. Bought an original one and just had it blasted.
Under the engine paint I will be using a high zinc primer for corrosion resistance.
I am new to the forum, but I am a mechanical engineer who worked for John Deere, Mercury Marine and Tracker boats. I worked closely with paint engineers. Our own plus those at suppliers.
Terry
Terrysch is offline   Reply With Quote
Old 04-14-2019, 06:54 PM   #5
rjs53
I use vht roll bar and chassis paint. Its semi gloss, but it's durable.
2003 Dodge 2500
1969 C10
2014 Camaro SS/RS/1LE
rjs53 is offline   Reply With Quote
Old 04-15-2019, 01:33 AM   #6
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Terry
Looking forward to seeing a picture of that finished air cleaner Welcome to the site.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 04-14-2019, 07:27 PM   #7
70 shorty
Where's my beer?
70 shorty's Avatar
No. I used Krylon Gloss black on my valve covers on my Corvette, not high temp, and it has held up perfectly for more than 10 years.
70 C10, shortstep, .30 over 250,Hurst shifted 3 spd parts hauler. Holley 390, Clifford Intake, Header, ported cylinder head, unknown bigger cam.
79 Corvette L82, 4 spd, black, red interior, headers, flowmasters, and unkown bigger cam.
'03 Grand Cherokee Laredo, 4.0 4x4 daily driver. 165K miles, and runs great
'08 Tahoe LTZ 4x4 155K
70 shorty is offline   Reply With Quote
Old 04-14-2019, 09:21 PM   #8
jlampka
Thank you all for sharing your experiences, saves time! Love this site!
Old 04-14-2019, 10:33 PM   #9
Coalkracker
You can use plain old rustoleum, no engine paint needed. My father did his air cleaner on his 70 impala 22 years ago and still looks new.
Coalkracker is offline   Reply With Quote
Old 04-15-2019, 10:19 AM   #10
Sloonz
I used VHT engine matte black. The finish is more like satin and looks factory.
Sloonz is offline   Reply With Quote
Old 04-15-2019, 11:28 AM   #11
Terrysch
Sloonz,
Where did you buy the VHT engine black matte/
Thanks,
Terry
Old 04-15-2019, 04:10 PM   #12
Sloonz
Autozone...but O'Reilly or Napa should carry it too.
Sloonz,
Thanks,
Terry
Old 04-15-2019, 04:18 PM   #13
May70
May70's Avatar
Just a FYI but I used dupli color engine enamel from advance auto on my valve cover, intake and exhaust manifolds. I was told that 292 runs really hot... burned off on the exhaust manifold within a day or two but the rest seems unphased. I used the chevy orange and the clear. Looks pretty good for spray bomb.
May70 is offline   Reply With Quote
Old 04-15-2019, 07:07 PM   #14
bill3rail
bill3rail's Avatar
I do not think any paint will survive on an exhaust manifold.
Old 04-15-2019, 07:14 PM   #15
Coalkracker
Engine paint is not meant for exhaust manifolds or headers. Usually it can only take about 500 degrees before its cooked.
Any decent enamel should work fine for you. If you go with VHT dont use their epoxy paint line. It is not a true epoxy paint and has zero resistance to some chemicals and is not very durable.
