Old 05-02-2019, 02:05 PM   #1
hfd410
hfd410's Avatar
Dakota Digital LS swap oil pressure sender question
This has likely been covered but when not using the BIM and using Dakota's sending units how are you getting oil pressure reading to the pcm ? Dakota says their guages have to read their sender. Does this require a second oil pressure sender to be tapped somewhere either for it or the pcm ?
My 71 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=548438
hfd410 is offline   Reply With Quote
Old 05-02-2019, 03:12 PM   #2
Nodnarb76
Nodnarb76's Avatar
Re: Dakota Digital LS swap oil pressure sender question
My setup may be different than yours but, my oem oil pressure sender was not used on my swap. The sensor was there but not plugged up. The harness I am using doesn't have the plug for the oil pressure switch. From what I have read, most LS swap don't need an input from the oil pressure sender.
I Just used the sender that came with my gauges and, have had no problems.
1987 R20 Suburban LQ4/4L80e swap: http://67-72chevytrucks.com/vboard/s...d.php?t=693824
Nodnarb76 is offline   Reply With Quote
Old 05-02-2019, 05:31 PM   #3
MDPotter
MDPotter's Avatar
I don't know what your sender looks like, but if it's like the sender that New Vintage provides with their gauge packages, you can buy an adapter from LSX Innovations that replaces your OEM LS oil bypass plate. There are a couple different configurations in terms of how many ports it comes with and I ordered mine from Amazon.
https://www.lsxinnovations.com/produ...rs-relocation/
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632
1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047
1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184
1978 Chevy Scottsdale K20
1993 Chevy C1500 - 5.3/T56 swapped
2008 Silverado Duramax
MDPotter is offline   Reply With Quote
Old 05-02-2019, 08:26 PM   #4
mongocanfly
mongocanfly's Avatar
The ecm does not need oil pressure input...all you need is the proper Dakota sender for your gauge...and if its npt sender then you'll need the metric to npt adapter..
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 05-02-2019, 10:18 PM   #5
hfd410
hfd410's Avatar
Thanks guys, makes sense now
Old 05-03-2019, 12:01 AM   #6
ls1nova71
ls1nova71's Avatar
Nice looking truck! I used to have a real similar one. Whether or not the PCM needs the oil pressure sensor depends on what year your engine is, but I'm going to assume its a GenIII since you didn't mention otherwise, so if that's the case you don't need it. To install the DD sender you can either tap the bypass block above the oil filter or you will need an adapter to put it in the stock location. Be careful with aftermarket adapters because they are usually pretty thin and will snap off easily, seen it done several times. Or, you can do what I do and break off the plastic part of the original sender and drill and tap it for your sender. Super easy, cheap and wont break like the aftermarket adapters. There are pics in my thread in post #26. https://ls1tech.com/forums/conversio...-c-10-a-2.html
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 05-04-2019, 04:48 PM   #7
bigmoe
bigmoe's Avatar
You need the original sender and hook up to ECM if you ever want to read gauges on a tablet with a Bluetooth scan tool for anyone who wants to do that.
bigmoe is offline   Reply With Quote
