Old 05-04-2019, 11:53 AM   #1
michael bustamante
michael bustamante's Avatar
Need your help on tire size fellas
Okay so I'm going to be running 15 by 10s in the rear with 295 50 15 and 15 x 7 in the front but I don't know what would be a good size front tire for this. my truck is a 67 short bed Stepside with 3 and 1/2 inch drop in the front with drop spindles and 4 inch drop in the rear. So it has a pretty good rake. What do you guys think?
1967custom
michael bustamante is offline   Reply With Quote
Old 05-04-2019, 12:28 PM   #2
RodnRudy
RodnRudy's Avatar
Re: Need your help on tire size fellas
I'd go for a 225/60/15 on the front. That tire will be 1" shorter than your rear and look correct I think. Here's a link to a site where you can visualize the tire sizes.
https://tiresize.com/calculator/
Phil
"Money is only a tool to create and achieve what you want most in life"
PayPal: rodnrudy@comcast.net
RodnRudy is offline   Reply With Quote
Old 05-04-2019, 01:27 PM   #3
HO455
HO455's Avatar
295/50/15's with 245/60/15's that were on the Burban when I got it. With that combination the front and rear tires have the same outside diameter. Sorry that the photos are not better but maybe this helps you.
RIP Bob Parks.
Old 05-04-2019, 02:31 PM   #4
dave`12
dave`12's Avatar
Here is mine, I think it might have looked better a little taller, but you might like it.
rims are 15 x 10
275 60 is the size
1967 C-10 4-speed, 350v8
dave`12 is offline   Reply With Quote
Old 05-04-2019, 09:19 PM   #5
Mike C
Mike C's Avatar
Best mod I did on my 69 short step was getting away from 15" wheels and tires. I'm running 17's all the way around now. 8's in the front and 9's in the rear with 235 55 17 and 275 55 17 respectively.
Just don't see why a build would include 15's at this point. More options in tire size, wheel choice, and backspacing and they clear better IMO.
Just say no to 15" wheel combos.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 05-05-2019, 07:54 AM   #6
HO455
HO455's Avatar
rims are 15 x 10
275 60 is the size
Your truck is beautiful. Just rolling perfection!
RIP Bob Parks.
Old 05-05-2019, 11:43 AM   #7
dave`12
dave`12's Avatar
Wow what an encouraging thing to say. She is far from perfect, but your comment helps validate the uncounted hours I have spent working on her.
Old 05-04-2019, 09:48 PM   #8
jocko
jocko's Avatar
Personally, I would let the suspension establish the rake, or leveling, or whatever you're shooting for stance-wise, and search for a front tire that has close to or slightly less than the outer diameter of the rear tire (since you are already set on it). Tire Rack and Tire Barn have pretty user friendly websites that allow you to search by size and see specs - you can do it with any tire, BFG T/As are available in almost any size, so that's a good one to do the search with to determine what size is about right to match the diameter you're looking for. Then you can search for that size in the tire you want (if different than a BFG T/A). That at least helps you see what is available. It's just personal opinion - but, to me, when the tires are used to establish rake rather than the suspension, the front tires tend to look too short and squat with too low of an aspect ratio.
EDIT: I realize now I just said about the same thing that HO455 said. But he had pics!!
Old 05-04-2019, 11:00 PM   #9
michael bustamante
The picks up a lot and less thanks a lot! And Jocko understand what you're saying. The check already sits at a rate. I'm just looking for a good Tire to match their ears and feeling the wheel well pretty decently without looking like all Tire. From the link you gave me, it looks like my best bet is going to be the 245 60 15
1967custom
