Old 11-28-2003, 01:37 PM   #1
willow72
willow72's Avatar
Unhappy hard starting after warmed up?
i have a 350 vortec crate motor it starts fine in the mornings or after it sits about an hour but if i drive it up to the store and try to run in and out it acts like the battery is about dead i just put a new starter on thinking this would fix the problem but it didnt timing seems to be right the starter i put on is one of those gear reduction high torq starter any help would be great
willow72 is offline   Reply With Quote
Old 11-28-2003, 01:47 PM   #2
jef5150
Inline 69
jef5150's Avatar
when you say replace starter,did you replace the soleniod also?did you replace the battery cables w/starter?????
jef5150 is offline   Reply With Quote
Old 11-28-2003, 01:49 PM   #3
jhwkns
Registered Cruiser
jhwkns's Avatar
Welcome to the board! Try disconnecting the ignition, and then rolling the motor over with the starter. If it rolls over normally, it's not a starter problem, but an ignition problem instead. Make sure all of your cable, and battery connections are clean. Good luck.
I intend to live forever. So far, so good.
jhwkns is offline   Reply With Quote
Old 11-28-2003, 02:14 PM   #4
willow72
willow72's Avatar
yes i did replace the solenoid and cabels as well
Old 11-28-2003, 02:20 PM   #5
ljbear
ljbear's Avatar
How hot is it getting? My wife had a 65 Mustang that used to do this, turned out to be a cooling problem. The radiator cap wasn't holding enough pressure, and as soon as she turned it off it would over heat. Cold starting was fine.
Larry
72 Chevy SWB 4x4
71 Chevy SWB 4x4
My Work Truck
"Don't confuse enthusiasm with capability"
ljbear is offline   Reply With Quote
Old 11-28-2003, 02:27 PM   #6
Randy70C-10
Randy70C-10's Avatar
You running headers? They sometimes have the tendency to do that. You may just need some header-wrap or a heat shield.
Randy70C-10 is offline   Reply With Quote
Old 11-28-2003, 03:07 PM   #7
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
sounds like ya need a heat shield there
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 11-28-2003, 03:13 PM   #8
jku72
My 68 burb did that when I first got it. I ended up discovering that I had the timing advanced a little too much. When it was cold, no problem, but hot, forget it.
jku Cornville, Maine
68 C10 burb
42 Willys MB
46 Dodge WF-32 1.5 ton
53 & 56 Olds'
60 Cadillac
22 Dodge Brothers
jku72 is offline   Reply With Quote
Old 11-28-2003, 03:27 PM   #9
jorgensensc
jorgensensc's Avatar
Mine was doing something similar. It had a new starter and soleniod and cables. I ended up getting an Optima red top battery (the battery that was in there was new, but it was a Costco battery) and the problem was solved and never came back again.
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 11-28-2003, 03:54 PM   #10
willow72
willow72's Avatar
thats what im doing right now waiting for my optima battery tobe deliverd
Old 11-28-2003, 06:42 PM   #11
shuttermutt
Don't say "Oops!", Doctor
shuttermutt's Avatar
Re: hard starting after warmed up?
Okay, when the engine's hot it still cranks, but slowly, right? That's not the solenoid, but much more likely the timing is too far advanced for the engine's liking. You say the timing is right, but what's it actually set at?
I've always timed my Chevy V8's by advancing them until they either A) start to detonate (ping) and/or B) are hard to start when hot. Sure, I could set 'em to what the book says, but every engine is different. I've had some that would let me get away with 14 degrees and others that wouldn't take more than 10.
Either way, I'll be a gen-u-wine dollar bill that's the problem.
'Mutt
1968 CST LWB: R.I.P.
1967 Chevelle: TPI 454 beast
1967 C10 SWB: Claimed when Bumpster didn't put it on his list
shuttermutt is offline   Reply With Quote
Old 11-28-2003, 10:19 PM   #12
Eddie H.
Eddie H.'s Avatar
When I worked at the Chevy dealer , many years ago. This was a
common problem.
Gm had a heat shield we used to put on that goes around the solenoid.
I don't know if they're still available or not?
"Negative people always seem to have a problem for every solution"
Eddie H. is offline   Reply With Quote
Old 11-29-2003, 06:14 PM   #13
willow72
willow72's Avatar
my timing is set at 9 degrees before top dead center is that about right the specs say it should at 10 degrees anymore help out there
