Old 05-15-2019, 04:05 PM   #1
m00n1957
starter wiring question ??
Small wire that goes to solenoid that engages starter on my truck must be broken somewhere in the harness, I can engage starter by jumping with screwdriver but turn ignition and nothing but lights, starter won’t engage with key. I need to run another small wire to starter, anyone know where this wire runs thru firewall ??
m00n1957 is offline   Reply With Quote
Old 05-15-2019, 04:18 PM   #2
mongocanfly
mongocanfly's Avatar
Re: starter wiring question ??
should come thru the fuseblock on firewall
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 05-15-2019, 06:28 PM   #3
geezer#99
geezer#99's Avatar
Did you check your neutral safety switch?
That might be your source of no power.
Old 05-15-2019, 07:18 PM   #4
m00n1957
Checked wires all are solid to firewall. hooked another neutral switch and still no start unless you cross fire on starter with screwdriver. Acts like bad neutral switch but it’s not. 86 Silverado with tilt wheel.
Old 05-15-2019, 09:56 PM   #5
kipps
Back-probe the terminals coming out of the ignition switch. This will tell you definitively whether the problem is in the switch or the wiring. Physically getting to that switch will be the challenging part. I don't know anything about the tilt columns.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome!
kipps is offline   Reply With Quote
Old 05-15-2019, 10:36 PM   #6
Dead Parrot
A broken tooth on the sector gear inside the steering column will also cause that symptom. As will a bad ignition switch.
Dead Parrot is offline   Reply With Quote
Old 05-15-2019, 10:47 PM   #7
kidatheart
kidatheart's Avatar
Won't a bad solenoid do that, also? I not sure.
kidatheart is offline   Reply With Quote
Old 05-15-2019, 10:58 PM   #8
sweetk30
sweetk30's Avatar
i have seen the master power switch on top of the steering column get out of adjustment just to the point all works except the starter power feed in crank .
otherwise its yellow wire before safety switch then purple out of the switch to the starter .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 05-22-2019, 05:15 PM   #9
m00n1957
i got pissed and left it alone for awhile and without touching anything I thought I’d hit starter and all of a sudden it starts. I rigged me a bypass starter button so I wouldn’t get stranded until I get it figured out. Next gonna pull column and check switch on top of column. Thank all
