Old 05-16-2019, 09:23 PM   #1
Dodge68charger
Rear Coil Spring Insulators?
Anyone Running Them or do I need Them or Do The Rear Coil Springs go Straight Spring To Frame? Thanks
Dodge68charger is offline   Reply With Quote
Old 05-16-2019, 09:36 PM   #2
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: Rear Coil Spring Insulators?
Coils are mounted to the trailing arm and the frame by a set of steel "cups" that hold the center of the coil.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 05-16-2019, 09:43 PM   #3
Dodge68charger
No Rubber Pads Inbetween?
Old 05-16-2019, 10:47 PM   #4
saxart
saxart's Avatar
Correct. No rubber.
Meet "Old Roy": http://67-72chevytrucks.com/vboard/s...d.php?t=707801
saxart is offline   Reply With Quote
Old 05-17-2019, 02:17 AM   #5
Dodge68charger
Originally Posted by saxart View Post
Correct. No rubber.
Thank You
