Old 05-17-2019, 04:01 PM   #1
Dodge68charger
Anyone Make Their Own Door Panels?
If So What Material Did You Use As Backing And How Did You Fasten Them To The Doors?
Dodge68charger is offline   Reply With Quote
Old 05-17-2019, 04:19 PM   #2
Mike C
Mike C's Avatar
Re: Anyone Make Their Own Door Panels?
I did in my Jimmy. I used 1/4" plywood, covered it with black vinyl. I used stainless sheetmetal screws and stainless trim washers and just screwed the 4 corners. I mounted 4" speakers in them and used 69-71 padded armrests.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 05-17-2019, 04:43 PM   #3
cebra
Not to highjack but the PO may be interested in this as well, what glue did you use?
My Daily Driver Build: http://67-72chevytrucks.com/vboard/s...d.php?t=755668
cebra is offline   Reply With Quote
Old 05-17-2019, 07:05 PM   #4
Mike C
Mike C's Avatar
I don't think I even glued them. I stretched it around the back and through the speaker holes, door handle and regulator holes and stapled it on the back with 3/16 T50 staples.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 05-17-2019, 04:42 PM   #5
cebra
I used thick sheet metal and bead rolled a few "stripes" near the bottom and covered in vinyl (I used 3m spray glue and they came off so I need to get better glue). I am using those chrome trim screws (with the washer thing around the head) to install.
Old 05-17-2019, 05:41 PM   #6
ga-stepside
ga-stepside's Avatar
I had bad luck with that 3M stuff too. I now use marine grade contact cement. It will hold up to the heat inside the passenger compartment.
1967 C10 Step side
1970 AMX 390
1977 Datsun 280Z highly modified with '95 LT1 power
ga-stepside is offline   Reply With Quote
Old 05-17-2019, 06:12 PM   #7
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Anyone Make Their Own Door Panels?
I went to my local shop and bought the board they use and cut the pattern out and then had them cover it for me. I did the dash pad and covered the 67 Chevelle wheel with same color leather.
There not perfect by no means but they cover up the 6x9 holes in the bottom of the doors and they are fastened like late model panels with the plastic tree's.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 05-17-2019, 06:53 PM   #8
Grumpy old man
Grumpy old man's Avatar
A brand new set of steel door panels are only $55.00 from rock auto
https://www.rockauto.com/en/catalog/...oor+panel,1296
I've made several sets for members using their door panels or fabricating them from waterproof door board . If you have your original panels they can be wrapped with any color vinyl and reinstalled .
Old 05-17-2019, 07:00 PM   #9
Grumpy old man
couple more
