Old 05-19-2019, 10:42 PM   #1
A.Delaney
A.Delaney's Avatar
Can anyone help with radio wiring on an 03
I bought this 2500 work truck. It had AM FM radio only from the factory. The guy that I bought it from had installed an aftermarket radio and it quit working a couple weeks later. I have the stock radio but he had cut the factory plug off the wiring harness. I went to the junk yard and found a 03 Chevy cargo van. I cut the plug out of it thinking I could splice it back in. I figured same radio same harness. Well the plug fits in my radio fine. Both the plug and my truck harness have 11 wires. However the colors aren’t the same and I’m not sure if the wires are in the correct pin locations for my radio.
The black with the white strip is the ground. One of the orange wires is constant 12v. I was guessing the other smaller orange wire was a keyed hot but I wasn’t getting anything on my test light. The remaining 4 pairs go to each speaker I assume. If the plug was the same. I figured I could match the wires but that’s not the case. I tried plugging in the harness to see if the radio would power up using the black as the ground and the red as positive but I got nothing. I need to figure out if the wires in the plug are right per the radio. Any help here would be great. Thanks
72 Chevy C20
86 Silverado Shortbed
A.Delaney is offline   Reply With Quote
Old 05-20-2019, 07:28 AM   #2
Re: Can anyone help with radio wiring on an 03
This may help ya out.
Sierra Radio Constant 12V+ Wire: Orange
Sierra Radio Switched 12V+ Wire: Yellow
Sierra Radio Ground Wire: Black
Sierra Radio Illumination Wire: Gray
Sierra Stereo Dimmer Wire: Brown
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Old 05-20-2019, 09:57 PM   #3
A.Delaney
A.Delaney's Avatar
Thanks Bill.
72 Chevy C20
