05-25-2019, 08:06 PM | #1 |
Removing ignition lock cylinder 1968 Chevy C10
I am trying to remove the ignition lock cylinder in my 1968 Chevy C10. I turned the key to accessory and inserted a paperclip into the lock cylinder hole. Then I tried turning the lock cylinder counter clockwise to remove it but it just will not come out.
I then tried spinning the chrome bezel out of the dash to try and get some leverage on the lock cylinder while holding the back of the ignition switch and I still cant get the lock cylinder to pop out. What is the trick to getting it out? |
05-25-2019, 09:36 PM | #2 |
Re: Removing ignition lock cylinder 1968 Chevy C10
"Spinning the bezel" is not a step in removing the lock cylinder.. Re-tighten it and leave it alone until you have removed the lock cylinder.. Turn the key to the "ACC" position.. Insert a paper clip into the hole and push in enough to depress the spring loaded pin behind the hole.. Turn the key counterclockwise and the lock cylinder should come out.. I use a large paper clip as it is less likely to slip off the pin..
05-25-2019, 10:44 PM | #3 | |
05-25-2019, 11:15 PM | #4 | |
The procedure I outlined above is the ONLY way, without damaging something, to remove the cylinder.. When you feel the pin depress and release, retract the paper clip ever so slightly.. Sometimes the paperclip will enter the grove that the pin "rides" in, thus preventing the cylinder from rotating enough to come out.. Use patience and don't add any additional steps to the procedure.. You're dealing with a very old assembly, so work gently.. It will come apart.. Some person in the past may have put some grease or oil in there and gummed up the works.. |
05-25-2019, 11:35 PM | #5 | |
Posted via Mobile Device |
05-25-2019, 11:59 PM | #6 | |
05-25-2019, 11:41 PM | #7 |
The Older Generation
As Rusty said that is the only way to get it out except for destructive methods. After the cylinder starts turning past the ACC position you have to remove the paper clip or it will bind in the hole. Then turn the key a little more to the left and it should come out. I have had a few that were a real pain to get out. There are two small tabs on the cylinder that have to line up with slots in the switch housing before the cylinder will slide out. LockDoc
05-25-2019, 11:57 PM | #8 | |
05-26-2019, 11:03 AM | #9 |
Like Old51 I always spray some WD40 in it & it comes out pretty easily.
George |
