Old 11-29-2003, 07:20 PM   #1
skokie
skokie's Avatar
Manifold Install
Ok I have the new performer manifold for my 350 with gaskets and I am about to go install it. Which way is best to remove the carb from the manifold or remove the manifold with the carb on it? The upper radiator hose and distributor are the other things that will need to come out.Is there anything else I am forgetting?
skokie is offline   Reply With Quote
Old 11-29-2003, 07:33 PM   #2
rage'nrat638
rage'nrat638's Avatar
TRANS. VAC HOSE..
LINKAGE
PCV HOSE
MISC. VACUUM HOSE'S
POWER BRAKE VAC. HOSE...
I WOULD SAY REMOVE THE CARB....PUSH RAGS INTO THE HOLES
ON INTAKE TO KEEP FROM DROPPING IN A BOLT
THE REMOVE IT.....
CAPS...SORRY
then clean all surfaces very good....clean....clean....clean....
do not use the rubber seals for the front and rear of the intake...
USE SILICONE......
old indian trick......
use a punch,,, and punch little dots across the rear rail and front rail,,of the block and a few on the bottom of the new intake...
when the silicone sets...the little punch marks hold ,,,it in place
rage'nrat638 is offline   Reply With Quote
Old 11-29-2003, 07:34 PM   #3
BtnkBndt
Pennyless Fool
BtnkBndt's Avatar
This will help.
http://edelbrock.com/automotive/gene...ral_instr.html
"Who owns this car with the peace sign, the mag wheels, and four on the floor?"
67 Short Step
283/TH400/4.11
BtnkBndt is offline   Reply With Quote
Old 11-29-2003, 08:18 PM   #4
jef5150
Inline 69
jef5150's Avatar
torque sequence
youll need a torque wrench,i scanned a pic to show you which order to torque the bolts,i hope its ok, jeff
jef5150 is offline   Reply With Quote
Old 11-29-2003, 09:13 PM   #5
skokie
skokie's Avatar
Thanks for the sequence jef5150. I was about to ask about that until I found it in the box. What do I torque it to?
RIP to my son Dylan. 5/17/2002 - 8/18/2018
If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started.
https://slothforpedcancer.org
68 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=223234
