Old 06-09-2019, 02:02 AM   #1
SilverGT3RS
2003 LQ9, Entropy and Exp. Tank
Trying to figure out if I need to go ahead and run an expansion tank like the factory did on my new Entropy radiator. I went to electric fans, and its a 2003 LQ9 with and new LS radiator from Entropy.
From what I can tell, the cooling system is supposed to run pressurized at the expansion tank, or at least looking at the diagrams it appears thats the way it was originally set up.
The expansion tank keeps the motor from getting an air bubble that could hamper the cooling, correct?
Any help would be appreciated!
SilverGT3RS is offline   Reply With Quote
Old 06-09-2019, 07:36 PM   #2
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
Re: 2003 LQ9, Entropy and Exp. Tank
Ran stock 87 non pressurized tank .... aka stock reservoir.. for 7 years no problem. People have problems when they don't bleed the system from the start.
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 06-09-2019, 07:54 PM   #3
mongocanfly
mongocanfly's Avatar
I'm also using the 81 overflow tank on mine..no issues...
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 06-12-2019, 03:04 PM   #4
Nodnarb76
Nodnarb76's Avatar
I've been running a OEM overflow tank with an Entropy radiator/Cooling fans myself for about 3 years with my swap. you should be fine.
1987 R20 Suburban LQ4/4L80e swap: http://67-72chevytrucks.com/vboard/s...d.php?t=693824
Nodnarb76 is offline   Reply With Quote
Old 06-16-2019, 12:28 AM   #5
Ghost's68
Ghost's68's Avatar
My buddy and I knocked out this over flow tank from left over intake tubing we had laying around. I’m running an LS3 with and Entropy Radiator and over flow tank. No issues with temps. Highest I seen was 195*. On a side note run green antifreeze if you run a overflow tank.
Ghost's68 is offline   Reply With Quote
