06-09-2019, 10:35 PM | #1 |
Experience with copper nickel tubing for fuel line??
I've read somewhere this stuff is much easier to work with than typical steel tubing and would like to give it a try. Does this stuff work well with inverted flare applications? Tight bends? Any thoughts would be appreciated.
Steve weim55 Colorado |
06-09-2019, 11:03 PM | #2 |
Re: Experience with copper nickel tubing for fuel line??
I used it. 3/8 nicopp. Worked well. easy bends. Flares easier than steel. Won’t rust. A little more expensive but I thought it was worth it. I bought 25 feet and only really needed 10-15 for my in bed tank
06-09-2019, 11:32 PM | #3 |
It polishes nice too. Looks good on multiple carb setups instead of rubber hose.
I do steel a lot but I cheat. I buy pre-made brake line straight sections a little longer than I need at the parts store. That way I already have a double flare on one end I'll be using and when I get the tubing bent like I want I only have to double flare one end per line. Tom
'69 swb stepside in progress. '59 Corvette lifetime project |
06-09-2019, 11:51 PM | #4 |
All about them K’s
This is all I’ll use. It bends easy, flares even easier, and it won’t rust.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
06-10-2019, 12:28 AM | #5 |
What flare tool are you using? I rented a couple kinds from autozone and oreillys and they both made crooked flares. I used them as you are supposed to but the part that crimps is always crooked as it gets tight. They are cheapo
06-10-2019, 10:00 PM | #6 | |
I bought the whole stainless line set from inline tool a couple pieces didn't survive shipping well and rather than wait for shipping again I tried to flare some stainless myself after the first one i flared failed to seal and I have been bending my own lines for years . I tried some of the nycop I will never use stainless again . even the larger tubes bend so easy and look so good when finished . although the tube might not rot the fittings will so if you flare your own get the stainless fittings makes it look better too |
06-10-2019, 12:44 AM | #7 |
All about them K’s
https://www.amazon.com/OTC-4503-Stin.../dp/B000L7QZ0Q
I have this one and it works great on steel and nicopp both. I’ve got a lisle one as well that works good too. One key to a good flare is the prep on the tubing, if you follow the directions in this kit you will get good results.
06-10-2019, 01:01 AM | #8 |
I have a Mac tools inverted flare/bender kit that I’ve used for years with steel tubing and it works great. Sounded very appealing to have tubing (nickel copper ) That would be easier to work with. Where are you guys purchasing a nickel copper? I noticed Summit sells it, any local suppliers?
Thanks for the replies , Steve weim55 Colorado |
06-10-2019, 02:48 AM | #9 | |
06-10-2019, 07:39 PM | #10 | |
06-10-2019, 09:35 AM | #11 | |
All about them K’s
06-10-2019, 02:40 AM | #12 |
I plan to use copper-nickel (shouldn't it be called "cupric-nickel?") on my 2002 Accord this summer. Fuel and brake lines running under car are badly rusted.
I wish I had used copper nickel on my truck when I made new fuel and vent lines. Some auto parts stores will loan out flaring tools, may be no reason to buy a set. I installed a bench vise just so I could use the flaring tool but that's not necessary either. In case you don't know, take off your original line and lay it next to the replacement you plan to make. Try to mimic the bends and DON'T forget to put on your fittings BEFORE you bend. In my case I just used bubble flares for the truck. *If you still have the in-cab tank, why not add a fuel cut off valve behind the seat? It's pretty easy to do and fairly easy to reach....might come in handy in case of an engine fire or for anti-theft protection. |
06-10-2019, 03:03 AM | #13 |
Mbeef61....that's great that you have offered your left over tubing to a fellow member. Good job!
My local Advance Auto carries the copper nickel tubing so I assume every shop would. |
06-10-2019, 06:48 PM | #14 |
I was a little skeptical, but bought a 6ft pre flared peice from advance to use when I put on my new intake and carb. Haven't done it yet.
06-10-2019, 08:32 PM | #15 |
I used it for brake line as well, worked fantastic.
06-06-2021, 03:27 PM | #16 |
But Found Her 25yrs Later!
I just found out about this stuff and been reading up on it. My research was on how it holds up to ethanol.
I liked a post I found over at hotrodders. People use copper for making moonshine.
06-06-2021, 04:47 PM | #17 | |
The Older Generation
I've been using the NiCopp for quite a while. Here is what I posted about it in 2015. Quote:
LockDoc
06-06-2021, 05:59 PM | #18 |
Thanks for the detailed post!
06-07-2021, 12:13 AM | #19 |
