06-15-2019, 03:24 PM | #1 |
caliper ID
So its been 3 years since I started the truck build ...... and starting to get closer to end than beginning --- but as hooking up brake lines I pulled the calipers to test with compressed air - and no movement with over 100psi.
Anyone know how to ID these ? They are off a dodge dakota ....... but forget specifically which year.
FAKKY 57 PANEL BUILD |
06-15-2019, 04:44 PM | #2 |
Re: caliper ID
Looks like this 91 in the pic...https://www.carparts.com/details/Dod...8aAsK6EALw_wcB
06-15-2019, 09:35 PM | #3 |
Re: caliper ID
Only 100 lbs?
With the correct master cylinder in place, the pedal ratio must be great enough to produce 1200 psi system pressure under severe braking conditions. https://www.markwilliams.com/braketech.html
1951 Chevy Panel Truck |
06-16-2019, 11:42 AM | #4 | |
Re: caliper ID
Wasnt really sure of another way to test until it was hooked to MC. After coming from a junk yard and sitting for 3 years in my shed - just decided to spend the $50 to be sure ...... good point tho.
06-16-2019, 11:40 AM | #5 | |
Re: caliper ID
thanks !!
06-15-2019, 09:42 PM | #6 |
Re: caliper ID
Most GM caliper pistons will move with air pressure. But Chrysler?? Not so sure.
06-16-2019, 11:44 AM | #7 |
Re: caliper ID
So when fiddling with the NEW caliper - I added 100psi and blew out the piston. No biggie I thought and folded it all back in until I noticed the outer boot had a crack in it. Im going to assume it happened when I shot it out. #backyardmechanics
Is the boot just a dust protector ? Seems the seal is more the piston and inner cylinder itself ..... but not sure.
06-16-2019, 12:40 PM | #8 |
Re: caliper ID
just bought 2 new boots ..... will replace just to be sure no dirt/water gets in
06-16-2019, 07:15 PM | #9 |
Re: caliper ID
1) Pistons are installed with a C clamp and hand pressure. I would be surprised if one doesn't move with air pressure applied.
2) The cover is a dust boot. But without it the seal generally does not live a long life. 3) If you ever want to test the piston with air again, use a block of wood as a piston stop. |
06-19-2019, 05:37 PM | #10 |
Re: caliper ID
I just started reading this thread and was going to say that you were probably lucky that it didn't move, but then I read farther and saw that you found out what happens when it does move if there's nothing to stop it. Best teacher, experience.
06-20-2019, 10:29 PM | #11 |
Re: caliper ID
Yep, 91/92 or So Dakota. These are off a 92 Dakota I took them off when I had plans to run an Industrial Chassis crossmember but didn't get one before he quit making them.
Shop cat still isn't happy that I stripped and sold the Dakota as he slept in it for a while after I sold a door glass off it.
06-29-2019, 02:04 PM | #12 |
Re: caliper ID
Thats funny - shopcat.
So I bought the capiper rebuild kit ... and have tried both ways to put the boot on - ruining another one in the process so down to last one. 1) Seat the piston fully. Get the boot on the ring/groove. Then push down the boot edge to sit. 2) Piston out. put the seal on the groove and then seat piston and push in keeping everything center. Neither appraoch made much difference ..... this is what I end up with. Im thinking of just going like this and seeing waht happens since that piston doesnt travel that far. But thoughts or tips ?
06-29-2019, 03:18 PM | #13 |
Re: caliper ID
wife had a go with her fingernails ...... better
At least flush with piston now
06-30-2019, 03:20 PM | #14 |
Re: caliper ID
Along with front end repair and alignment I did brake jobs for a living for several years. I still hate rebuilding calipers and have had that same fight just about every time. I don't have a good answer either.
06-30-2019, 03:54 PM | #15 |
Re: caliper ID
I have found it easier to buy the rebuilt calipers and for most vehicles not much more money. Just picked up a set of calipers for the front of the S10 chassis under my 53 Chevy truck for $34 each side. Bolted on in less than 30 mins.
Wade
53 Chevy 3100, SBC 355, 700R4, S10 frame, Ford 8.8 rear with 4.11 gears, front disc & rear drum brakes |
