Active Member
![]() Join Date: Jan 2017
65 K20 Instrument Cluster removal
How do you remove the instrument cluster on a 65 K20? I have disconnected the speedometer cable and removed the 5 screws. The only other thing the manual says is to disconnect the oil pressure line, which I did not do because I have slack in it. It will not budge!
Do any of the switches have to be removed first? Are there secret clips I need to un-hook? Is there a special password I have to say? ![]()
Submariner616 1965 Chevrolet K20 350 4 speed manual |
![]() Join Date: Jan 2011
Re: 65 K20 Instrument Cluster removal
You have to pull all the switches and the choke cable. Most of the time there is a union in the oil pressure line just outside of the fire wall. Next I also disconnect the wiring harness. The bottom of the cluster can get hung up on the dash and some time you need to bend the tabs that stick up down just a bit to get them to clear. They get hung on the back of the bezzel and the harder you pull the tighter it will get.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
#3 | |
Active Member
