Old 06-23-2019, 09:22 PM   #1
dmartin1
dmartin1's Avatar
WTB 71 AC wiring pigtails/parts
I need the connector and about 5" pigtail for both-
Ac switch in dash
And the connector that plugs into the blower motor relay under glovebox. Mine are ruined.
And if someone has the clips that hold the sending unit wire to the top of the gas tank. I need a few of these.
Also, the flap door inside the hvac unit under the dash. My flap is broken.
1969 Shortbed in progress
1982 short step, few suspension and motor upgrades.getting a 468
1978 Shortbed fleet side bonanza fully loaded
1978 k20 Silverado loaded.currently engine-less
1989 k10 suburban 9" lift
65 nova
And more
dmartin1 is offline   Reply With Quote
Old 06-23-2019, 10:33 PM   #2
randy500
Re: WTB 71 AC wiring pigtails/parts
I have a complete ac wiring harness in good shape, $60 shipped which would be better than splicing all those wires. I could include the 3 clips you need.
The broken flap door isn’t replaceable but the diverter valve assembly is available new, most used ones are broken.
randy500 is offline   Reply With Quote
Old 06-24-2019, 12:05 AM   #3
dmartin1
dmartin1's Avatar
Randy, I'll keep that in mind.
My harness is good(wiring is good) it's the black connectors, the housing pieces that are broken. Figured its be easiest to try and get a cut pigtail.
I realllllyyyy dont want to rear everything back apart to replace the harness if I can get the black ends and re-pin them.
Idk how to go about finding those?
65 nova
And more
Old 06-24-2019, 05:43 AM   #4
aotte1
I will take the AC harness and parts if Dmartin1 passes if correct for 72’.
Les
aotte1 is offline   Reply With Quote
Old 06-24-2019, 10:20 AM   #5
dmartin1
dmartin1's Avatar
aotte, go ahead my friend.
65 nova
And more
Old 06-24-2019, 01:23 PM   #6
Madkidd007
Madkidd007's Avatar
Ac switch in dash
Pretty sure I have the wiring pieces you need in a cab at the house. If so I’ll send you whatever is left of the ac harness for $20 to your door. I’m 99 percent sure it’s still in there
70 C10 highschool truck now C20 cummins powered
72 Crew Denali, Bigger, Stronger, Faster, well you get the point.....
the ole 65 continental
Syclone killer AWD T56 LS
Paypal please pay as Goods&Services Madkidd00000007@yahoo.com
Madkidd007 is offline   Reply With Quote
Old 06-24-2019, 10:15 PM   #7
Madkidd007
Madkidd007's Avatar
Sorry I have to slightly retract my previous statement. The only thing cut was the lighting side of it so I’d lean more towards $30 shipped as it’s easiely repairable. My apologies.
