![]() Join Date: Jan 2018
Pulling Motor, and Transmission
Getting ready to pull the motor and the automatic transmission on my '72 Jimmy.
Is it best to try to pull the motor and transmission together, or is it better to pull motor first, then the transmission. I wasn't planning to remove the transfer case. Do I need to pull that too, or does the transmission release from the transfer case easily? Thanks, Pat |
Re: Pulling Motor, and Transmission
Just unbolt the transmission from the transfer case and it will slide right out. There will be less complications if you take the engine out first, then the transmission. Usually the complications stem from not having an engine hoist that will go high enough.
Also, if you decide to pull the engine and transmission as one unit, tape a thick plastic bag on the end of the transmission so that you don't spill all the fluid out because the unit will have to be tilted at a high angle for removal. |
I did as you said, and pulled the motor first.
Will pull the transmission tomorrow. I do have a receipt that the transmission was recently rebuilt, but I thought that having it this far, it would be crazy not to go through it. Any idea why the numbers 505 are on the radiator support, and the same 505 number is on the AC unit? Pat |
The 505 is the build sequence. These marking were put on the factory floor. If you look closely, that number should also be at the top of the firewall.
Carpe manana
![]() ![]() Join Date: Dec 2010
Any more detail pics of the motor or firewall you can share? Documentation of survivors can be really helpful for future builds.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
Off the wall, but what if your firewall was white? do they change the crayon color?
Yes. So it is faint but I believe it was black 22 on my firewall and a white 22 on my core support
Justin 1970 Blazer in progress |
Fire wall pic
Man....I took several pictures of the motor, and the firewall. I'll see if I can download a few.
A few more.
Carpe manana
Thanks for posting! Really well depicts the vac lines AC hoses and shows what is possibly the factory location for the zip tie affixing the AC muffler hoses with the hoses to the charcoal can. The brass cap nut on the muffler is OEM - too cool.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() Last edited by DeadheadNM; 07-06-2019 at 09:43 AM. |
