06-29-2019, 10:54 PM | #1 |
Trying to figure out why my fuel gauge doesn't read correctly
On my 1968 Chevy C10 the fuel sending unit had already been replaced with a new one by the previous owner but that did not fix the problem of the fuel gauge not reading correctly. The gauge reads empty with the key on however when you turn the key on and then remove the wire to the sending unit the needle for the fuel gauge instantly moves to the 3 oclock posiition and stays there but when you put the wire back on the needle then goes right back to the empty fuel location.
Anybody have any ideas on what could cause this? Last edited by LockDoc; 06-30-2019 at 12:11 PM. |
06-29-2019, 11:11 PM | #2 |
Msgt USAF Ret
Re: Trying to figure out why my fuel gauge read correctly
Your fuel gauge sending unit wire is grounded to the frame and is not going through the sending unit resistor. Trace the wire from the sending unit back to the gauge and you will find where it is touching the cab or frame. If you can get to wire where it runs under the door sill you'll probably find it is worn through the insulation and is touching bare wires to the metal.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
06-30-2019, 01:34 AM | #3 |
Do I have the same problem if my gauge stays at 3 o clock all the time? I've found your older post about the fuse, but my fuse box did not look like the picture
06-30-2019, 01:55 AM | #4 |
06-30-2019, 02:08 AM | #5 |
I just pulled up that will trying to reach my selector valve I will be replacing soon. I will look for that wire
06-30-2019, 07:29 AM | #6 |
Just by pass the old wire with new wire rather than tracking down the area of the short.
My build page http://67-72chevytrucks.com/vboard/s...d.php?t=764662 My cabinet building site http://www.cbcabinets.com |
06-30-2019, 07:45 AM | #7 |
If he has a short somewhere along that wire then why would disconnecting the sender change that? I don't get your thinking. I think more likely he has a short in the sender.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme. |
06-30-2019, 10:25 AM | #8 |
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
06-30-2019, 12:14 PM | #9 | |
Msgt USAF Ret
Reading his post I answered his question about the zero reading. I also assumed that he was disconnecting the sending wire at the gauge, but you are correct that if he disconnected the sending wire at the sender he would be removing the path to ground for the gauge. If the sending unit is grounded, an ohms check between the terminal and the flange would show that, provided there is fuel in the tank.
06-30-2019, 02:14 PM | #10 | |
06-30-2019, 11:48 PM | #11 | |
Msgt USAF Ret
Here is the diagram or how it's wired.
07-01-2019, 01:25 PM | #12 | |
07-01-2019, 04:17 PM | #13 |
Re: Trying to figure out why my fuel gauge doesn't read correctly
The float on the end of the sending unit is probably full of gas.
George |
07-02-2019, 01:08 AM | #14 |
That's a very good possibility.. I've had 4 float failures within the past year on my new sending unit.. Each failed at the solder seam joining the two float halves.. The float fills with gas, causing the float to sink to the bottom.. the sending unit goes low ohms resistance and the needle points to "E"..
