Old 07-08-2019, 09:20 PM   #1
JerryIndy2112
JerryIndy2112's Avatar
71 GMC Grill restoration
My 71 GMC truck that I bought in November of 2018 has had a few projects keeping me busy. I rebuilt the quadrajet, new front calipers, hoses and new rotors. Last week I put in a new HEI distributor, still working on getting timing just right, but she is up and running ok. Today I pulled of the front grill. It has some dents and the chrome really needs cleaned up. The black paint is almost gone. It needs straightened. Cleaned and painted.
Who here has done this? I am biased, but I think the GMC 71 and 72 grill is the coolest ever put on a truck. I will post a picture of what I am working with. I work in HVAC and have done a lot of simple sheet metal work, but a total newbie with body metal. Wish me luck, can't wait to get this part of the truck restored. Any hints and tips would be useful. Paint? How to straighten metal? All comments are appreciated.
Jerry
JerryIndy2112 is offline   Reply With Quote
Old 07-08-2019, 09:26 PM   #2
jeffahart
jeffahart's Avatar
Re: 71 GMC Grill restoration
If you're a tin knocker and you work on custom sheet metal work for commercial kitchens and such, then you're a shoe in. Check out this article.
https://www.jalopyjournal.com/forum/...lified.799131/
j
White K20
jeffahart is offline   Reply With Quote
Old 07-08-2019, 09:27 PM   #3
JerryIndy2112
This is grill off
Old 07-08-2019, 09:30 PM   #4
JerryIndy2112
Thanks jeffahart, looks like a good article.
Old 07-08-2019, 10:14 PM   #5
mikeshome
mikeshome's Avatar
Like your taste in trucks.
mikeshome is offline   Reply With Quote
Old 07-08-2019, 10:34 PM   #6
JerryIndy2112
very cool truck Mikeshome.
What year is that? The paint that I can see on my 71 is a bit different. I like the paint on your grill. I am thinking that is the way to paint mine. Just checking to see what is correct. I assume you are 71 or 72, but which? Your paint is very crisp, mine is very faded. You can see by my picture. In my opinion, what is correct for each year and what I like as the owner are different decisions that I will make. Thanks for the pictures.
Very nice.
Jerry
Old 07-09-2019, 07:23 AM   #7
'71 and '72 are identical in every way. That top bar is an available separate part. It looks like something I would just replace before fixing. The straightening of the dings and dents , if painting, is the same as on body sheet metal. Unfortunately, rechroming is pretty much cost prohibitive. I mean way expensive, like through the roof.
I repainted the accent black on my '72 in '01. The chrome is dull but it still looks much better with the black redone. The headlight doors were really dull and I think starting to rust, so I did my own thing and painted all but the flat outer surface. I think it looks better than chrome... on my 4wd truck anyway.
Here is how the paint has held up over the years. I used low gloss black engine enamel
Old 07-09-2019, 09:42 AM   #8
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
I like the way you did the headlight doors. It gives it a "don't mess with me" look.
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 07-09-2019, 12:11 PM   #9
notsolo
notsolo's Avatar
I cut blocks of wood, on the table saw to match the profile inside and out...Lay the damaged area in the vee cut and work from the inside. Tapping with wood blocks of different lengths .
notsolo is offline   Reply With Quote
Old 07-09-2019, 01:53 PM   #10
71gmcC15
71gmcC15's Avatar
You could polish up the hole grill and leave it chromed like I did.
( second times the charm) 71 gmc c15 307 sbc 373 rear gears positrac sm 465 trans. ( not listed on spid but is original )
94 chevy k1500 350 tbi 373 rear gears 4l60e one wheel peel. Gutless
07 gmc sierra classic rcsb 4.3 lt 5 speed w/t
04 chevy Silverado 1500 ext cab 5.3 4l60e.
81 chevy Scottsdale k10 muncie sm465 Np208 10 bolt 8.2 ( Old Green)
71gmcC15 is offline   Reply With Quote
Old 07-09-2019, 08:53 PM   #11
JerryIndy2112
I went to take off "eye brows" and found that I am not sure how. Do I have to take off fender?
Old 07-09-2019, 09:27 PM   #12
mikeshome
mikeshome's Avatar
Thanks mine is a 71,i bought mine the way it is and that was 10 years ago.The brows on my lights are just the crome ones held on by the bulb screws.
Old 07-09-2019, 09:32 PM   #13
JerryIndy2112
Hey
What do you mean by "bulb screws"? Do you mean you just pry them off, then pop them back in?
Old 07-09-2019, 09:42 PM   #14
I think one of you are talking about the fender brows and the other headlight doors. To remove the fender brows you need to get at the backside to the nuts
Old 07-10-2019, 12:42 PM   #15
54blackhornet
54blackhornet's Avatar
I’ve had numerous 67-72’s but this 71 GMC gets comments when ever I park it even for just a moment. It’s the grill , pulls folks in every time. They also notice the H4 headlights.
71 C-20
07 Magnum RT AWD
54blackhornet is offline   Reply With Quote
