Old 07-09-2019, 07:53 PM   #1
GMCNUT
GMCNUT's Avatar
66 BBW SWB Fleetside Custom Cab V8 3 spd
I want to share this You Tube video link with all of you because I think this truck deserves a good home where it will get repainted and enjoyed. I bought it to use as the donor body to restore my rotted 66 but damn - this truck is way too nice and operates too smooth etc to take it apart when technically all I really need is a replacement BBW solid 64-66 cab so I am offering this great solid truck up to all of you and I will hunt a cab to fix mine instead. Pass this link around to your truckin' buddies? https://youtu.be/wAO8e_oXCck
This is a real barn find 66 short bed pickup bought new and stayed right here in NE Alabama all its life with 81K original miles, all its factory fawn paint inside, Custom Cab Big Window, and a nearly 100% solid cab. Late model V8 replaced the original 283 back in 1985 when it was unfortunately sprayed Burgundy straight over the original Light Blue and White paint - so to top it off it has the coveted 537 paint code. Original Custom Comfort seat was recovered to match the outside and sits great. 3 speed trans never hangs and operates flawlessly.
Rear end is quiet, front end nice and tight. Great ride and you can tell it was never ragged by anyone. all Glass is great. Watch the video and I don't think anyone will question the under-valued price of $8500 firm on this truck - I know you wont when you see it in person and actually drive it.
Text or Call 256 486 1988 Thank you - I can arrange to deliver it myself and maybe within the price depending on where you are
My Projects and Toys - All 100% Stock
1972 CST "Highlander" Blazer - 350 auto, PS, PB, A/C, Tilt, Tach, AM/FM & Positraction
1966 Chevy SWB Fleetside BBW Custom Cab, #'s matching 327 V8 & Powerglide, factory deluxe heat, PS, PB, Tinted Glass, sway bar
1961 Chevy SWB Fleetside BBW Custom Cab #'s matching 283 V8 & Powerglide w/ uber-rare Cool-Pack A/C, factory PB, deluxe heat, Clock
1961 GMC K1000 4x4 SWB w/ BBW, Custom Cab and numbers matching 305D V6 engine & 4 spd
1960 GMC SWB Fleetside BBW Custom Cab #'s matching 305A V6 & Hydramatic, factory PB, Clock, Tach, Compass, Hood Jet
1959 Chevy SWB Fleetside BBW Custom Cab w/ rare stainless bed trim, #'s matching 283 V8 & Hydramatic, Deluxe Heat, radio, spotlight
1958 Chevy Cameo #'s matching 283 V8 & Hydramatic, radio, window washers, Factory PB
1958 GMC BBW SWB Fleetside Custom Cab, #'s matching 336 V8 Hydramatic, Factory PS, PB, Clock, RSD, Deluxe Heat & Hood Jet
1957 GMC Suburban Pickup (GMC's Cameo) #'s matching 347 V8 Hydramatic, uber-rare vacuum ashtray, Factory PS, PB, Clock, RSD, Hood Jet
1956 Chevy 3800 1 ton w/ rare 9 ft stepside bed, factory 265 V8 w/ Hydramatic, factory PB, Custom Cab, deluxe heat, spotlight and hood jet.
GMCNUT is offline   Reply With Quote
Old 07-09-2019, 08:01 PM   #2
GMCNUT
GMCNUT's Avatar
Re: 66 BBW SWB Fleetside Custom Cab V8 3 spd
When you watch the video, you won't be able to believe that a Big Window cab exists with this little rust in it, but seriously - here is a topside shot of the floor rust shown in the video - same on both sides in the exact same spot - that IT for cab rust on this one.
DOES NOT NEED OUTER ROCKERS
DOES NOT NEED INNER ROCKERS
DOES NOT NEED CAB SUPPORTS
DOES NOT NEED CAB CORNERS
DOES NOT NEED FLOOR PANS
DOES NOT NEED CEILING REPAIR
DOES NOT NEED DOOR BOTTOMS
Crazy solid - just sand it and get the hundred year old un-necessary bondo off the panels and see what you need to truly repair - maybe repair or replace front fenders but the rest of this truck is sooo much better to fix and repaint than 90% of them
Old 07-09-2019, 10:38 PM   #3
gmcbigbl
gmcbigbl's Avatar
$8500 ha hahahaahahahahhahahahahha
gmcbigbl is offline   Reply With Quote
Old 07-09-2019, 11:20 PM   #4
GMCNUT
GMCNUT's Avatar
You don't have to show all your fellow board members the douche you can be
Old 07-09-2019, 11:48 PM   #5
chtr65
Is this post for real?
chtr65 is offline   Reply With Quote
Old 07-10-2019, 01:55 PM   #6
GMCNUT
GMCNUT's Avatar
I know right? For someone accustomed to seeing through the floorboards like people in Pennsylvania do, floors this solid have to appear to be a dream. Probably bring 10K if I had it in PA for sale
Old 07-11-2019, 08:05 AM   #7
nsb29
nsb29's Avatar
Everybody knows what they think their truck is worth. Original 327 three speed standard original wood bead and soft ray glass. The only rust in the whole truck was of coarse the bottom of both front fenders. It does not have the side trim and it is not a big back window, and the Seat has been sat in. A solid straight southern California truck for a third of the money Name:  D01301EF-C9BB-40E5-9848-563ECAA6732E.jpg
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent
nsb29 is offline   Reply With Quote
