Old 12-01-2003, 12:22 AM   #1
Illinois CST
dana transfer case
Hey guys, I have a 70 blazer with a four spd manual and apparently a dana transfer case. Apparently, too much throttle snapped the output shaft. Does anyone have any info on these cases? Parts availability etc.. I don't know much about them. Would it be better to replace the shaft, or should I just look for a different transfer case? Thanks, Willie
1970 Blazer CST
350 700R4
Illinois CST is offline   Reply With Quote
Old 12-01-2003, 02:42 AM   #2
1969 GMC
1969 GMC's Avatar
What engine do you have?
Transfer case is a Dana 20, and IIRC they are fairly common transfers, not in Blazers but more so in Jeeps and maybe Scouts. Good luck.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 12-01-2003, 10:04 AM   #3
Illinois CST
I have got a 350. Thanks for the info. If anyone has this output shaft, or has any other suggestions, I'd appreciate the advice. Thanks, Willie
1970 Blazer CST
350 700R4
Old 12-01-2003, 10:49 PM   #4
blazomatic
Dana t-case
I have 2 Dana 20's. I used to have one in my Blazer. I replaced it with a 4-speed 205. So a Dana 20 will also bolt up to a 4-speed? Cause I thought they just came behind 3-speed manuals. Is the transmission to T-case adapter the same for all manuals? Sorry to butt in on your post.
blazomatic is offline   Reply With Quote
Old 12-01-2003, 10:52 PM   #5
Illinois CST
I also read that the dana's were only behind a 3 spd, but apparently they also were with the four spd with granny low. What did you have to change when you put in your 205, blazomatic?
1970 Blazer CST
350 700R4
Old 12-01-2003, 11:38 PM   #6
blazomatic
Nothing. I lucked up and found a guy that had the whole set up for sale in the local paper. He rolled his '71. I got the trans, t-case, cross members, shifters and all. I took my 3-speed out and put in the four speed. I used my 3-speed cross member cause it was in better shape. My drive shafts worked. From what I've heard the Dana 20 was fairly common in 4x4 Blazers. Behind the 6 cyclinders and the 307 (like I have). Another member has the 3-speed and Dana 20 for sale $100 I think. I have one I would get rid of but I'm kinda far away. You could probably find one closer.
Old 12-02-2003, 12:07 AM   #7
Illinois CST
Thanks for the info, blazomatic. I'm not sure what I'm going to do, I have been thinking about putting an auto in it sometime anyway, this might have forced my hand. I have a parts truck with a TH350 and NP203 so I might try to stick that in. It is good to know that a 205 might fit behind the 4spd without changing driveshafts though. Thanks again- Willie
1970 Blazer CST
350 700R4
Old 12-02-2003, 05:07 PM   #8
slicknsmooth72
i have a dana i will part with out of jimmy with 350 moter for $100.00 + shipping pm me if interested
slicknsmooth72 is offline   Reply With Quote
Old 12-02-2003, 10:23 PM   #9
72 Blazerman
Chevelle Nutt
72 Blazerman's Avatar
blazomatic, what are you asking for the Dana 20? I'm in northern va.
Doug
71 CST Blazer 4X4, 350, on da tree
81 Blazer 2wd 350 350
99 F*** Ranger, I know, I know but it's cheap transportation
83 Mustang GT 5.0 4 speed loaded
"got cubic inch?"
72 Blazerman is offline   Reply With Quote
