07-17-2019, 01:54 PM | #1 |
Loose/Bad bearings in steering column
As this truck came to me it had already been modified with car parts, my guess is a '64 Impala. I do not know if the steering column is original '51, or if it is from a car. It had an Impala steering wheel on it.
The problem I have is there is a bearing at the top of the shaft that is bad and needs replacing. However, I am not sure how to obtain this bearing, and whether to look for a '64 Impala bearing, a '51 Chevy truck bearing, or something else. And, I figure to replace the entire steering column at some point, so if the bearing is any more than 20 bucks it's not worth bothering. Here's a video of me moving my steering wheel/shaft: https://youtu.be/aiO_s6C0CGY |
07-17-2019, 03:05 PM | #2 |
Re: Loose/Bad bearings in steering column
My 53 column is just a straight 2" tube. I don't know about car columns but on my truck if you remove the wheel you can carefully pry out the bearing and replace it. It's not expensive. Unhook the horn wire and be careful with it. It's not attached very well.
07-17-2019, 08:05 PM | #3 |
Hey thanks for the response. My hangup isn't removing the bearing; it's finding a replacement one. I stopped in at O'Reilly's Auto Parts today and asked them to look it up. Just as I had been finding online, I cannot reference the bearing in anybody's search engine. They did say I could remove it and they would measure it and try to find one that works. Maybe I should search a newer year truck? I'm hopeful someone here has had to do this and knows what part to use and where they got it.
07-17-2019, 08:45 PM | #4 | |
07-17-2019, 09:17 PM | #5 |
Id have to agree...you know its bad..just pull it ,,match it ,,,replace it...if the column has been changed theres no telling what's in it...and I'll have to say,,I've never seen one worn that bad...has it always been that way?..makes me wonder if you have some mismatched parts...
With the dimensions, they can usually match about anthing..
07-18-2019, 09:48 PM | #6 | |
07-17-2019, 09:35 PM | #7 |
I'd say its original to the truck. It goes right into the steering box, or the column and steering box are more or less one unit.If it were from a car, it would have a different box and column. It's easy to put any gm steering wheel on in place of the truck wheel. Bearing will most likely be the up to 54/55.5.
07-18-2019, 07:42 PM | #8 | |
07-18-2019, 09:54 PM | #9 | |
07-18-2019, 10:54 PM | #10 | |
Restoration parts source EO175-CCCP-0363 California Classic Chevy Parts $17.56 You can probably find it other places also. all t.he venders have them |
07-18-2019, 11:35 PM | #11 |
judging by the pics I would say the steering box is going to be crying the blues soon as well. it is very close to the headers and will likely cook unless you put some heat shielding there. it has gear oil in it, usually, so if you start smelling hot gear oil and find a leak it is likely the box telling you it is too hot. check the lube level in the box to see if there is actually lube in the box as well.
i have replaced the upper column bearing before. not that tough but, like said, watch out for the horn wire. |
07-19-2019, 12:50 PM | #12 | |
I may swap in a new steering column soon. If I do I will obviously be checking the gear oil. Otherwise, I'll need to be keeping an eye on it like you said. |
07-20-2019, 09:26 PM | #13 | |
07-20-2019, 08:37 PM | #14 |
07-20-2019, 09:15 PM | #15 | |
Unfortunately it looks like this fits 1955-1957 Chevrolet 210 model cars, and I'm uncertain if it fits for my truck. I might have to wait until Monday and give them a call. |
07-19-2019, 12:06 AM | #16 |
Chevs of the 40s kit #270255,$48.00.brg,with horn wire,spring and retaining clip. 47-54.
Just another option for you.. |
07-19-2019, 12:46 PM | #17 |
Thanks, that's the kind of lead I was looking for. Still, I'm thinking I'd rather spend the money on a new column if the part is going to cost me 20-50% of a new column. I found a guy selling a black one with tilt on Craigslist for $120.
07-19-2019, 04:15 AM | #18 |
I'd at least pull the steering wheel and see what's going on in there....
07-19-2019, 12:47 PM | #19 |
07-20-2019, 07:55 PM | #20 |
mmmm...thats bad...looks like the ones linked above are what you need..never tried ,but can the bearing be pressed out?
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 07-20-2019 at 08:00 PM. |
07-20-2019, 08:15 PM | #21 |
just buy the complete unit like posted above and swap it out. easy. we have all spent cash on some pretty silly things. this is steering, don't sweat the 50 bucks. some places will deliver to the door even.
07-20-2019, 11:28 PM | #22 |
i noticed the 48$ ones had the wire already on them pn270255
