Old 07-17-2019, 02:41 PM   #1
Anthony14
Fuel pump
Hi guys. I have a SBC350 with a TH350. TCI 2500 Stall, 3.42 gears, Brodix IK200 heads, 224/234 cam with .491/.519 lift. Holley 750VS, Edelbrock Performer RPM intake.
Took my truck out for a cruise and hammered the gas. Pulled through 6500rpm, I shifted into second, then when crossing 5000rpm it started bucking and kicking like it was starving for fuel. I did this 3 times and everytime was the same. I'd let off the gas, she'd catch up, and continue to cruise normally.
I feel like if this was a ignition problem then regardless of what gear I'm in it could happen constantly at that rpm. I'm thinking my mechanical fuel pump is going; I'm burning up the fuel in the carb through the initial first gear pull then by the time I hit second the carb is empty and the pump can't keep up.
This is the second NAPA fuel pump, first one just flat out died. I pulled up the specs and it's only rated for 23GPH. After doing some research I'm not sure that's even close to sufficient. I have 3/8" fuel line front to back. I'm thinking I need a fuel pump and considering the Edelbrock 1721.
Anthony14 is offline   Reply With Quote
Old 07-17-2019, 04:19 PM   #2
Steeveedee
Who Changed This?
Steeveedee's Avatar
Re: Fuel pump
Maybe pull the sock on the sender in the tank and see if it is clogged some. It doesn't take much when it's working on suction instead of pressure when it comes to fuel flow. Do you have a filter between the tank and the pump? If so, that would be a place to look, too. Squeeze you fuel line between the tank and the pump to make sure it isn't too soft and collapsing.
~Steven
Simi Valley, CA
Old 07-17-2019, 04:28 PM   #3
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
Re: Fuel pump
Might be the float settings, did you check them?
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 07-17-2019, 04:34 PM   #4
Anthony14
Re: Fuel pump
Still just below the sight windows, rock the truck slightly and fuel spills out.
Old 07-17-2019, 04:33 PM   #5
Anthony14
Re: Fuel pump
I should have mentioned; tank is brand new, Camaro tank that's at the back of the truck. Sending unit is brand new as well. All rubber is new, and any joins are under 2" of rubber in length. I do have a filter after the pump before the carb and it's clean.
Old 07-17-2019, 04:44 PM   #6
Ironangel
Ironangel's Avatar
Re: Fuel pump
What kind of ignition, HEI or points? And what is the initial timing? And 23GPH is way low, should be 80+ GPH...
"Two Seventy Two's"
02 3/4 ton Express
Old 07-17-2019, 04:59 PM   #7
Anthony14
Re: Fuel pump
It's a Taylor HEI 640000 distributor. MSD Streetfire wires, with the plugboot protectors. I can't remember exactly, I want to say initial is around 10, and all in is 36.
I figured 23GPH is too low. I found a formula online and if my combo puts out about mid 400hp I should be at around 40GPH at a min, so makes sense to just flat out upgrade.
Old 07-18-2019, 05:52 PM   #8
68 P.O.S.
Re: Fuel pump
Do the instructions say how much mechanical and vacuum advance it provides? Is the vacuum advance adjustable?
72 C10 lwb fleetside -stock 350/350 combo
68 P.O.S. is offline   Reply With Quote
Old 07-21-2019, 09:28 AM   #9
Anthony14
Re: Fuel pump
I tried searching it can't seem to find any specs. It is adjustable.
Old 07-21-2019, 02:20 PM   #10
HO455
HO455's Avatar
Re: Fuel pump
Before buying any parts I would determine where the problem was. You could hook a temporary fuel guage up and determine for sure if fuel supply is the problem.
I had very similar problem years ago on my GTO caused by running an air cleaner base plate without the top. Not that that is your problem but I went through the whole ignition system (swapped distributors, bypassed the resistance wire etc) and the fuel system (changed fuel pumps, tore the q-jet apart at least twice, and dropped the fuel tank to inspect it.). Before I sat down and started testing things logically I was just wasting time and money.
Good luck.
RIP Bob Parks.
Old 07-17-2019, 05:14 PM   #11
jeffahart
jeffahart's Avatar
Re: Fuel pump
So may I ask. Does your RPM drop under load? Does the same amount of foot feed result in the same RPM under varying load? Maybe it's not the RPM explicitly. Just an interpretation of the response.
Perhaps it's your throttle linkage. Check out my post here. You never know what evil lurks in that linkage. Assume nothing.
http://67-72chevytrucks.com/vboard/s...d.php?t=742187
j
White K20
jeffahart is offline   Reply With Quote
Old 07-17-2019, 05:29 PM   #12
tdangle
tdangle's Avatar
Re: Fuel pump
I agree it's your fuel pump. Looks like Summit Racing has a Edelbrock clone for about 1/2 the price. Might want to check it out.
https://www.summitracing.com/parts/s...20-1?rrec=true
Terry
1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC
tdangle is offline   Reply With Quote
Old 07-17-2019, 05:49 PM   #13
Anthony14
Re: Fuel pump
I'll check it out. Thanks.
Editied: I ended up ordering and ACDelco unit part #12355612 from RockAuto. Should be more then enough at 110gph, and with the 3/8 fittings everything should fit.
Old 07-17-2019, 07:37 PM   #14
Steeveedee
Who Changed This?
Steeveedee's Avatar
Re: Fuel pump
One more thing- is the fuel pickup at the rear of the tank? Maybe the fuel sloshes back and you don't have the pickup submerged in fuel?
~Steven
Simi Valley, CA
Old 07-17-2019, 08:31 PM   #15
garyd1961
Re: Fuel pump
Check your fuel filter(s). Even if they are fairly new it doesn't take long to clog if you are running the origiial tank. I have to change mine about once a year.
garyd1961 is offline   Reply With Quote
Old 07-17-2019, 10:36 PM   #16
Anthony14
Re: Fuel pump
Pickup is middle of the tank, and the tank was over half full.
Old 07-17-2019, 05:47 PM   #17
Anthony14
Re: Fuel pump
j
If I'm understanding your question right; yes, the rpm drops when going up hill without adjusting my foot position. I would have to give it more gas to maintain a constant speed.
Old 07-18-2019, 04:58 PM   #18
Wrenchbender Ret
Re: Fuel pump
"Bucking & kicking" sounds like maybe the hydraulic lifters are pumping up. 6500 rpm is pretty high for hydraulic lifters.
George
Wrenchbender Ret is offline   Reply With Quote
