Old 07-20-2019, 06:43 AM   #1
Jemezcrusher
Tail light wiring mod
I saw a post by a guy that used stainless tubing to run his wires from his tail lights. Despite numerous searches I can not find it. Any help would be appreciated
Jemezcrusher is offline   Reply With Quote
Old 07-20-2019, 07:42 AM   #2
1project2many
Re: Tail light wiring mod
http://67-72chevytrucks.com/vboard/s...2&postcount=11
Here's his build thread. It may have more details.
http://67-72chevytrucks.com/vboard/s...d.php?t=557675
1project2many is offline   Reply With Quote
Old 07-20-2019, 01:21 PM   #3
Clay54
That's a good method also but I think the one jemezcrusher is referring to is actually stainless steel tubing. I remember the post also but cannot remember who did it. Clay
Clay54 is offline   Reply With Quote
Old 07-20-2019, 08:42 PM   #4
dsraven
I have also seen guys use nylon air brake tubing and compression fittings for a weather proof and neat look. heavy though compared to simple wiring and loom.
Old 07-20-2019, 10:07 PM   #5
Clay54
Here it is. Clay
https://www.google.com/search?q=tail...e7Q8a8wBuRtyM:
Old 07-21-2019, 07:07 PM   #6
Jemezcrusher
Originally Posted by Clay54 View Post
Thanks. That is what I was looking for
Old 07-21-2019, 02:44 AM   #7
Livemeyer
Livemeyer's Avatar
I did this:
Livemeyer is offline   Reply With Quote
Old 07-21-2019, 11:40 AM   #8
e015475
e015475's Avatar
Here's one I recently made for my '49
I closed out the hole on the bracket where the wire went through and welded on a -6 AN fitting. I took the rubber wire seal out of the tail light and make a 3/16" rubber gasket that goes between the bracket and the light to make sure it sealed out water
Here's some detail of the bracket. The nut and the tube are stainless and I'll polish those up some. The nuts on the tail light will get replaced with some polished stainless acorn nuts to clean it up a bit
The stainless tube takes some doing to bend it. I have a cast metal tube bender, but I borrowed this Parker bender to get a little more leverage
e015475 is offline   Reply With Quote
Old 07-21-2019, 01:31 PM   #9
Livemeyer
Livemeyer's Avatar
Those look great!
Old 07-21-2019, 11:48 AM   #10
mr48chev
mr48chev's Avatar
Guys used to use the bendable chrome or stainless tubing for under bathroom sinks from the plumbing supply for that. I'm talking tubing and not hose.
My ongoing truck projects:
mr48chev is online now   Reply With Quote
Old 07-22-2019, 02:15 PM   #11
pvienneau
pvienneau's Avatar
I used this from Stovebolt and it worked great.https://www.stovebolt.com/techtips/e...ght%20bracket/
Pat
1949 unmolested Indy Farm Deluxe AD
1949 Standard 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=581544
pvienneau is offline   Reply With Quote
Old 07-22-2019, 02:22 PM   #12
Livemeyer
Livemeyer's Avatar
I tried that first but the conduit came apart really easily as I was trying to work it into the tail light bracket. I also couldn't figure a good way to use or mount the conduit on the truck end. What did you do at the truck end of the conduit and wiring?
Old 07-22-2019, 02:26 PM   #13
pvienneau
pvienneau's Avatar
It's held against inside frame rail with tension of the wire.
Pat
