07-24-2019, 11:46 PM | #1 |
Coil suspension
Hey guys I just had my C 10 lower , rear springs, and it is sitting lower on one side can anyone confirm if there is a left and right? People that did it said there isn’t but the experts down the road “specialists” apparently said there is a left and right spring on rears.... it’s going back this weekend to see what the problem is.
The left looks to be fine sitting flush but the right seems to not sit so flush, would this be causing the issue, see pics, they told me they would get a spacer made up and put in it I said no im not keen on that idea it came in level it’s coming out level. Thoughts? |
07-25-2019, 04:35 AM | #2 |
Re: Coil suspension
Ha... never heard of left and right springs...how bad out of level does the truck sit?...spring spacers arnt a big deal but if you used new springs you shouldn't need them...some better pics of how it's all installed may give a clue
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 07-25-2019 at 04:45 AM. |
07-25-2019, 06:46 AM | #3 |
Re: Coil suspension
Did you have the front springs changed? They have been known not to seat in the top correctly. How much have you drove it? The springs will settle in and level up some over the first several 100 miles. Did you have any other work done?
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
07-25-2019, 07:58 AM | #4 |
Re: Coil suspension
To hard to tell from pictures, left hand rear sits lower, only the rear was lowered
The front is only about an Inch off the bump stops now. |
07-25-2019, 08:27 AM | #5 |
Re: Coil suspension
can they be rotated ?
07-25-2019, 06:56 PM | #6 |
Re: Coil suspension
07-25-2019, 12:11 PM | #7 |
67-72 parts collector,…
Re: Coil suspension
Rotate the rear springs where they both contact the trailing arm in the same spot.
It looks like in your pics, the right spring contacts the trailing arm on the front side of the spring,... and the left side on the rear of the spring. That's the best that you can do, since the springs are the same.
07-26-2019, 08:57 PM | #8 |
Re: Coil suspension
All sorted. Apparently when they lifted the front the front right hand spring came unseated which made the left rear lower drop, all seated all good.
07-26-2019, 10:35 PM | #9 |
Re: Coil suspension
Great..!!...nice looking red truck ya got there....
