ZR1 LS9 swap
Afternoon guys. I purchased a wrecked 2011 ZR1 to swap into my 1970 c10. Motor made 800hp to the tire before a low mph crash. My truck is basically stock with manual valve airride, front disc coneverion, 5 lug swap and power brakes. The trans I have is a tko600 unit from American powertrain.
I plan to try and use the zr1s aftermarket clutch, with a aftermarket hydraulic setup. There a few things I have questions on. Frame stiffener, would you use one or build one. Porterbuilt?? Those that have purchased was it worth it? 4 link or stay ladderbar? Would you use 2 piece driveshaft or stay with a single? What other suspension mods would you reccommend. I wrench and fab most anything. |
60-66 Nut
Re: ZR1 LS9 swap
At that power level I would stiffen the frame you have the means and the time, You could build it yourself. If you don't have a lot of 'spare time' then the porterbuilt unit looks to be a good piece as is all of their products.
I would stay with the trailing arms if that is what you have. If your truck is a longbed and has the HD 2 piece driveshaft and carrier bearing, I would stay with that.
Re: ZR1 LS9 swap
Thanks. The truck is a shortbed, I was unsure of with the airride it would need a 2 piece shaft. I'm new to the C10 and airride so learning.
I would typically build my own parts, but the porterbuilt has the ladder bar adjustments and geometry figured out, so I'm leaning that way. I was thinking of boxing the frame from stiffer back and adding a watts link and anti roll bars front and back. I was also thinking about going with PB front IRS kit to get a better front geometry and rack n pinion. Is this the best route or is there a better option than porterbuilt? I do have alot of fab equipment so some of the things I plan to build myself. |
![]() ![]() Join Date: May 2015
Re: ZR1 LS9 swap
Swb I would go with a 1pc d-shaft...but that's me...but the Camaro I pulled my ls3 from had a 2pc shaft about 4ft long....go figure....PB does make some very nice stuff...nothing wrong with fabbing your own stuff either though...
Really nice 70 ya got...
Re: ZR1 LS9 swap
Thank you. When I get some time I'll post some build pictures. Right now it currently has a blown head gasket ole 350. I got a l83 vortec crate motor for it but ended up with the ZR1 so I didnt put the l83 in yet. I'll be posting it for sale soon to offset some of this swap cost.
60-66 Nut
Re: ZR1 LS9 swap
In a shortbed a 1pc driveshaft will be just fine as long as it is of the correct diameter and wall thickness.
Re: ZR1 LS9 swap
Does Porterbuilt sell a frame stiffner that you can use a 1 piece driveshaft? It doesnt give me that option on the website.
60-66 Nut
Re: ZR1 LS9 swap
That I do not know. You might send them an email or give them a call on Monday and ask them about that.
Senior Moment
![]() Join Date: Mar 2002
Re: ZR1 LS9 swap
See Capt Fab about Hydraulic Clutch set up. His works Perfect
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 |
60-66 Nut
Re: ZR1 LS9 swap
Thank you for the recommend
Senior Moment
Re: ZR1 LS9 swap
Both my Son and I have your setup for Hydraulic Clutch in our trucks.
Easy install and works flawlessly Thank You
Re: ZR1 LS9 swap
Captainfab, what dies your kit include?
My biggest thought is which slave cylinder to use with the tko600 and how to make it work. I havnt pulled it apart yet to look at geometry of the unit. |
60-66 Nut
Re: ZR1 LS9 swap
With the TKO600 most of my customers use a hydraulic release bearing. Here is the for sale thread for the '67-'72 booster bracket with hydraulic clutch conversion.
http://www.67-72chevytrucks.com/vboa...d.php?t=652871
